richriddle
Gold Member
- Joined
- Feb 6, 2017
- Messages
- 261
- Location
- Taylorsport, Kentucky
- Tractor
- Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
My "Lincoln Log" seating is a bit embarrassing but works. Gary has two sources for the wheels and the ones on the tractor are from the better company. Yes they were not inexpensive but if one plans to keep the tractor for a long time, it's fine. He has the exact specs and they fit just like they were from the factory. Pay once; cry once. My experience is that it's cheaper to buy the exact fit product than repeatedly ordering an inferior product or trying to make something work not designed to work.Did he have these made for you or did he find something that fit. Bet they set you back alittle. I noticed your 2x4's.
every picture I've seen in the manual shows the hub with springs facing out. There's also 3 position holes in the axle for a pin to go through. Along with the two tension bolts. Can't see that there should any moment in the hub of everything is tight.Im a new owner of a 147d & wondered about the posibility of finding a set of used ag wheels/tires for my machine. It has the turfs on now but I also want a complete set of ags which i can switch back & forth between sets without having to dismount/remount tires when i want one or the other. Altho new would be nice, is there such a thing as a yanmar graveyard somewhere that you can find wheels?.... A more important question hopefully one of you can shed some light on for me is... which way are the rear hubs supposed to be facing? The bolts w/springs facing inside the rear wheel, or are the springs/bolts supposed to be on the outside of the wheel? If you look at the pictures in this thread i see them both ways. In my manual, it appears they are facing outside. Does it matter?
