I traded for a 336D with a FEL yesterday. It is supposed to be about a 1986 model. The hour meter showes 1050 hrs and wasn't working when the po first got it. The story is the po was brush hogging last summer and overheated the tractor. He came to the barn and let it cool off then refilled it with water/antifreeze and went back to brush hogging. The tractor was low on power so he parked it. The next morning it won't turn over.
Also the 4x4 never worked while the po had it. Lever felt like it was going into/out of gear when moved.
When I checked it out there didn't show to be water/antifreeze in the oil but, the oil was over full a bit which to me was indicating water was there. It still wouldn't turn over. The started engaged and sounded like it was pulling a load.
We hauled it home today and started the tear down expecting to find a cylinder full of antifreeze. There was no obvious antifreeze in the oil. When the head came off there was only the bit of antifreeze that spilled out of the passages. All the cylinders looked fine and they all looked the same.
Battery charger on the battery and it still won't turn over with the head off so I pulled the oil pan. There was about 1/2 cup of new looking antifreeze in the pan. It could have went in there when we pulled the head, I can't be sure either way. I did try turning the motor with a socket on the balancer bolt but no luck there. I did have the tractor in neutral.
Just looking at the bottom of the engine with the pan off everything looks like new. No tarnish, build up or gunk. There was a 1/4 inch of gunk stuck to the top side of the pan. It looked like 1/4 inch of oily grease. The oil pickup tube looked new and the mesh was clean.
I pulled the rear rod cap off and the rod bearing looks like new. No grit, streaks or significant wear. At this point I ran out of time so I thought I would post up to this point.
Next to do look at the front two rod bearings and then I guess pull the motor and look at the mains. Open for suggestions/ideas ect.
I had to pull the drive shaft to the front end, in doing so I learned the front pinion is worn out to where I can easily turn it by hand so now I know why the 4x4 doesn't work. I read about the front ends losing oil on here.
I am currently reading up on 336D rebuilds including Domushs' and I have already learned a lot, Thanks to everyone who has been posting these up!!
Pic's are coming.
Pic's are coming.
![20170818_182919[1].jpg 20170818_182919[1].jpg](https://www.tractorbynet.com/forums/data/attachments/465/465149-52dfb1e85059601f201fb1edd5f1d5b6.jpg)
![20170818_183032[1].jpg 20170818_183032[1].jpg](https://www.tractorbynet.com/forums/data/attachments/465/465167-07e5ed4053a28f93ccddaaf2d1ad4a93.jpg)
![20170818_182447[1].jpg 20170818_182447[1].jpg](https://www.tractorbynet.com/forums/data/attachments/465/465175-5e6e4521247de3a12e90f1ad72fdd29e.jpg)
![20170820_183732[1].jpg 20170820_183732[1].jpg](https://www.tractorbynet.com/forums/data/attachments/468/468394-815d54f95157203b3cb426c8efeec0ab.jpg)
