LD1
Epic Contributor
Let's recap....
You have a loader that was lifting very slow/weak.
You replaced the valve with a brand one (which seems to be a pretty popular aftermarket valve).
No change. Loader still lifts slow if at all.
Swapped hoses to curl side, loader works fine (but didn't test the lift spool on the curl.
Here is what we need to further assist....
Full valve part number. (Tells us weather Regen, float, spool position,open center vs closed, PB, etc.)
Then need a diagram of the valve and hose routing you have. Some pics would work.
Particularly, want to see if supply, return,and PB are booked up correctly, and lastly, if one of the spoons are Regen....to make sure you aren't trying to lift loader with that spool as it's meant for the curl.
The directions can get confusing with those valves. With multiple ways you can mount it, and adjusting the joystick to compensate.
What I think we have is an error during install. Valve orientation and joystick orientation not matched, or trying to use Regen spool for lift. Very unlikely that a new valve won't lift your loader. Even if the relief is set under 1000psi, cause most loaders only require 500-600psi to lift the frame + empty bucket
