Well...It's "fixed", but now I'm confused...I think :confused2:. Apparently, the connection on the end of the sending unit was slightly corroded...just enough that in my messing around with it during painting I had caused it to lose connection. I jiggled it around and now it's "fixed". The way it was acting before was: When pressing the "check" button...no light, when starting-no light, when running-no light. The key here is the "check" button-no light. My understanding of the system is that the switch (sending unit) is "normally closed" - with a completed circuit (and light) under low/no pressure conditions. Once the engine is running with sufficient oil pressure, the "switch" is opened, causing the light to "turn off". The corroded connection effectively "removed" the signal from the system so - no light...regardless of "switch position". Ultimately...I think the "check" button is more important than people give credit for. If you press the check button and don't get an oil pressure light you either have a bad bulb, or a bad connection. I don't think this in any way "checks" the sending unit...just the bulb circuit from the sending unit. Actually a pretty simple system, but I think nowadays people think buttons and such "do more" than they do on these older, simpler systems. Nevertheless...the "check button" is an important button, but it just checks the circuit.
