Here痴 what I致e got:
Classic slipping in forward a little and mostly reverse. I致e read enough to know I知 hunting for an issue in the lower shift area and that痴 not my question.
I removed the old gasket, ordered a replacement, put it on and it made no real difference. Took it off again and I realized the old gasket and the new were completely different. The old one seems like it is a proper mate for the transmission where it bolts on, but has nothing similar to the ridges on the mating surface of the regulator case. The replacement gasket has all the right ridges in all the right places for the regulator case but only the bolt holes line up and the outer shape of the piece seems correct but it痴 different.
The old one appeared to be the problem, as it showed signs of compromise throughout. The old one also appears to be the same one in the drawing in my service manual. But it痴 different. Hopefully photos attach here...I知 not a real mechanic but I致e played one in my garage/back yard for decades and I don稚 know where to start.
Has the regulator case been swapped out? Did they just update the gasket...?
