Re: 1500d front seal won\'t seal?
When the damage occured to the front outer drive housing, you may have deformed the upper or lower sealing areas. Even a small 'nick' may prevent proper sealing.
Did you completely remove the outer drive housing when you put it back together? On a bench top, you should be able to assemble the upper/lower halves and seat the unit completely.
If this was done in the field, there could be a small stone or some similar obstruction blocking proper assembly.
I've rebuilt the outer drive housings on my 1500D twice now, and some of the components (gears & shafts) can be very difficult and very expen$ive to find out there. Great pics!!! It's nice to know there are others out there working the living daylights out these little tractors! Holler if you need more assistance with the outer drive housings. Good Luck!!!!!
