YM1700 Draft control?
   / YM1700 Draft control? #1
Popstoy43
My 1700 has a handle on the drivers side lift arm that I assume is for the draft. There is an adjustment nut threaded at the end of the rod. Also the rod has about three holes drilled in it. It seems to make no difference which position the handle is in. Does anyone know the procedure for proper adjustment of draft? Thanks
   / YM1700 Draft control? #2
So would that be left or right drivers side? /forums/images/graemlins/smile.gif
I don't know of the 1700 having draft controll.. unles sthis was some sort of external feedback linkage a previous owner cooked up, that would adjust the 3pt control handle.. etc.
Soundguy
   / YM1700 Draft control? #3
Don't think it is draft control but my 3000 has the same thing on the left 3 point arm that is linked to the valve that controls 3 point arms up and down. This is a factory set up Soundguy. I asked at the importer what it is, no one knew. They had many on the floor with this feature. ( 20 or so of the 100 yanmars there had this feature ) Rocker that all of this is linked to presses a plunger raising or lowering the 3 point. I have a couple of operators manuals for mine and none address this feature, what it does, how to adjust.???? I to would be highly interested in what this setups intended use is.
Chris
   / YM1700 Draft control? #4
</font><font color="blue" class="small">( some sort of external feedback linkage )</font>
I think you nailed it, but it is not something added on. I'm not sure I can explain clearly but I believe it is a position feedback for the 3 point. I have seen them on the Yanmars before. I had one come loose and the hitch started acting real eratic and when I found and tightened the culprit, all was well.
   / YM1700 Draft control? #5
That was my first thought.. Fergie tractors and Ford N's also had a factory aftermarket 3pt feedback linkage as well as many many home brew setups. The attatched to the lift arms in various ways.. and used springs.. levers, and friction discs to modulate the lift handle for various things. In the fergy/ford case.. they turned draft 'only' hyds.. into psuedo 'position' control. I'm sure there are setups where as the implement follows the terain, that the falling implement could them modulate the 3pt handle to change something.
I like seeing neat mechanical linkages like that.. kinda reminds me of Rube Goldberg type stuff.. or clockwork.. etc.
Soundguy
   / YM1700 Draft control? #6
While we are all standing around prognosticating.. post a pic of that linkage.. I've not personally seen one on a yanmar.. a visual clue may go a long way towards an explanation.
Soundguy
   / YM1700 Draft control? #7
Tractors4u is correct . If you didn't have the linkage the control valve would keep supplying oil to the lift cylinder. If you adjust the rod it should change how far the 3 point raises or dropd.
   / YM1700 Draft control? #8
Hmmm. The operation manual says connect the feedback rod only to the 'P' hole, never the 'D' hole... Could D mean Draft Control?
Here's the diagram.
   / YM1700 Draft control? #9
</font><font color="blue" class="small">( So would that be left or right drivers side? /forums/images/graemlins/smile.gif
I got it!!! Funny!!!
I'll take a pic. tomorrow and post. By the way it's on the left drivers side unless you are sitting in the seat backwards. /forums/images/graemlins/cool.gif HE HE
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2024 New Holland T8.410 MFWD Tractor (A55302)
2024 New Holland...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
