1200 series tiller 2 to 3 point/ Any ideas-pic.s?
   / 1200 series tiller 2 to 3 point/ Any ideas-pic.s? #1
Popstoy43
Has anyone changed over a Yanmar 1200 series 2 point tiller to a 3 point set up? I really would like to see a picture of how it was done. I need fine spline shafts also.
Thanks, Leon
   / 1200 series tiller 2 to 3 point/ Any ideas-pic.s? #2
Attached is a the only photo I have of a 3pt RS1200 tiller. Its not mine, someone else posted it a while back. I am in the process of converting my RS1100 2pt tiller to 3pt. I have mounted the lift pins and made the top link attaching point. I have not yet tried to get a pto shaft for it. I don't use this tiller much at all since I also have an RS1000 for my smaller tractor. The smaller tractor and tiller is much more convenient and maneuverable for my small garden.
Thanks, Send me a pic. when you get the job finished. My tillers have a 16 spline shaft. From what I hear this is not a common size spline size. I haven't tried to locate yokes for them yet. Let me know if you run across any. Thanks, Leon
   / 1200 series tiller 2 to 3 point/ Any ideas-pic.s? #4
Of course I have the double u-joint that served as the pto shaft for the 2pt mounting. I was just going to saw it between the u-joints, have it turned in a lathe to make sure the two parts are square, then have pto shaft pieces welded to the two pieces where I sawed them. I think it should work OK. Fortunately, I have friends I can count on to do machine work when I need it.
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
Duetz Power Unit (A50120)
Duetz Power Unit...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
20" Sea Container (A47384)
20" Sea Container...
