FL_Jerry
3 point \"bounces\" when using FEL
This kind of ties in with a previous post I had about hooking up they lines for my Koyker 120 on my YM2000BD. I didn't notice till I put my bush hog on that when I use my FEL the 3 point raises up and returns to the previous level when I stop using the FEL.
I called Koyker and made sure that I had the power beyond hooked up correctly. I have a Joystick control that has the usual input from the pump and out to the high pressure line to the 3 point. I have a return line hooked into a port by the large knob under the seat.
Koyker suggested I adjust the control with the roll pin under the seat and I did that without success. If the 3 point control is all the way down, the 3 point doesn't move if I use the FEL. I can close the big knob under the seat and the FEL works without moving the 3 point.
I'm not sure how this setup operates to troubleshoot it. I know I could go to a simple in/out system on the high pressure line, if Koyker tells me how to plug the joystick. I'd really like to leave the power beyond setup if I can.
I changed the fluid and cleaned the screen when I did the install. Any suggestions?
Thanks
Jerry
YM2000, box blade, kyoker 120, bushhog.
Thanks
Jerry
