Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,856
    Central New Hampshire
    Kubota B3030HSDC
    Default Tapping into my hydraulics
    Under my seat is this block...... marked "in" and "out". Would this be a suitable place to tap into my hydraulics for rear remotes. I'm dreaming about a hydraulic top link, and perhaps hydraulic controls for the chute on my rear blower.
    Attached Images Attached Images
  2. #2
    Join Date
    Feb 2005
    Posts
    1,777
    Default Re: Tapping into my hydraulics
    I cant help you with the hydraulics part. but you might consider using electric motors to move the schute on the blower. there are several links in the search here. I can also tell you about mine. I used a wiper motor. and works good. no hoses or valves to deal with either.feel free to message me if your interested.
  3. #3
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,728
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by Ductape
    I do not know how good your manuals are (or if you even have them), but
    you will most likely need a hydraulic diversion plug if you use those ports.
    Does you tractor have a loader valve? Your photo does not look like the
    Yanmar (JD) tractors I have added remote hydraulics to.
  4. #4
    Join Date
    Feb 2006
    Posts
    4,856
    Kubota B3030HSDC
    Unfortunately, i do not have a service manual for my tractor.... though i should get one. The plugged ports under my seat are in the block where the pressure line goes into the rear of the tractor to power up the TPH. I don't think it would be a huge issue if using this port to power rear remotes would only allow me to use one valve (or the TPH) at a time...... as i don't forsee me wrestling two or more levers on the rear at a time. I was hoping someone here had used these, and could tell me if this would be an acceptable way to get hydraulics to the rear.
  5. #5
    Member
    Join Date
    Jan 2006
    Posts
    29
    Leicester England
    Yanmar YM186D
    Hi Ductape,
    I've copied the hydraulics page out of the Yanmar ym186d instruction manual for you......hope this helps......regards from over the water....Dean
  6. #6
    Join Date
    Feb 2006
    Posts
    4,856
    Kubota B3030HSDC
    Dean,
    Thank you very much. Some of it is not clear enough to read, but having the diagram showing where the return lines go is a big help ! I'm really stunned that no one here has done this....... or not offered any advise. Any chance you have aux. hydraulics on your tractor? Just curious if affected the three point hitch in any way. I need to find an OEM manual for my tractor.... i missed one on Ebay a while back !
    Scott
  7. #7
    Join Date
    Feb 2005
    Posts
    1,777
    You might give a PM to MadReferee
    He may not have seen your post, He seems to be very knowledgeable with Hydraulics.Wish I could help.
    Allan
  8. #8
    Join Date
    Feb 2006
    Posts
    4,856
    Kubota B3030HSDC
    Bedlam, I'm WAAAAY ahead of ya !!! Now that i have the schematics of it, hopefully with a little help i can get this done. He certainly seems to be the self-taught master of hydraulics !
  9. #9
    Join Date
    Feb 2006
    Posts
    4,856
    Kubota B3030HSDC
    Dean, could i get you to tell me what size fittings are required on the divider block? Its too blurry to see..... i belive this is "C" on the bottom left of the page. Also...... the return plug..... looks like 3/4-16 UNF w/oring ?
    Thanks again !
  10. #10
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
    Thanks again !
    3/4"-16 = SAE 8
    You should get a male o-ring SAE 8 to female of whatever male end your hose has. These types of adapters are common and should be available at any place that sells hydraulic fittings like DiscountHydraulicHose.com
    My friends call me Mad, everyone else thinks I'm mad.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
