Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Oct 2006
    Posts
    4
    Default 1900 need help
    front loader does not lift to much and when it does it will leak down to ground
    when i pick up loader it will slowly lower down,any info will help
  2. #2
    Join Date
    Mar 2002
    Posts
    505
    Tennessee
    Default Re: 1900 need help
    What brand loader do you have?
  3. #3
    New Member
    Join Date
    Oct 2006
    Posts
    4
    i looked all over no idea what type of loader please reply
  4. #4
    Platinum Member roxynoodle's Avatar
    Join Date
    May 2006
    Posts
    989
    NW Ohio
    Yanmar 1510d, 1950 Farmall H
    My advice may not be worth anything, but I'm wondering if the cylinders need repacked?
  5. #5
    Join Date
    May 2006
    Posts
    989
    NW Ohio
    Oh, and I have a Japanese loader and found the brand and model number on the loader control. It was hidden and I wouldn't have seen it without the control off the tractor. If yours is Japanese it might be a Kanzaki loader. Mine has curved arms and an industrial type bucket with teeth on it. If that helps any, I can post a pic of it later if you want to see it.
  6. #6
    Veteran Member BTDT's Avatar
    Join Date
    Sep 2006
    Posts
    2,209
    North Texas
    IH M Farmall-propane powered, H Farmall (father-in-laws), Ford 1300 diesel
    Sounds like relief valve may need adj/cleaned. May have broken spring, or as some have said, cylinder may need repairing. Does the curl feature work ok, or is it local to lift cyl. on loader?
  7. #7
    Join Date
    Apr 2002
    Posts
    2,086
    SW Ohio
    yanmar
    A loader on a YM1900 is typical of a very specific section of this market, which I will hence forth refer to only as a "very specific section of this market" lest it's defenders come out in force to lambast me---again. IF that is the case, it is likely going to be either a non-branded loader or a bulldog, and the only OEM parts (if there are even OEM parts to be had) will come from a dealer in this "very specific section of this market". That said, unless they are using completely bastard parts, one should be able to get most, perhaps all, of the necessary parts to repair cylinders from a good hydraulic supply source. None of this will substitute for someone with the knowledge to make a good diagnosis, so if you don't understand how the loader works, you probably need to 1. take it back to the seller, 2. find a dealer willing to work on it and take it there, 3. find a good independent mechanic to look at it for you.
    I know you don't want to hear this, but I would not invest a great deal of money, as the 1900 is a model older than most sold in this market, and not highly regarded...it's resale in the market among those familiar with Yanmar is poor. The upside is that there are enough parts out there for it to allow one to keep one going if you are already invested. (we can get most engine--piston/head gasket/etc-- and component--starter/alternator--parts)
  8. #8
    Gold Member
    Join Date
    Sep 2005
    Posts
    390
    ne kansas
    YM 2210
    Where are u? Where did u get ur tractor/loader? This might be a place to start. It does not really matter what brand it is. It is basic hydraulics. U have a pressure leak some where. Find the leak and fix the problem..... Some of these loaders are only design to lift about 700 pounds. That is ok cuz it is a pretty good match to what the front end of your tractor can support. If it is not lifting 700 lbs then u may have a flow problem. If you have a local Votech school call them and see if the class won't fix it for you!
    Great
  9. #9
    Join Date
    May 2006
    Posts
    989
    NW Ohio
    My second thought was check to see if a relief valve is stuck. Someone else mentioned it so it's worth looking at.
  10. #10
    Elite Member California's Avatar
    Join Date
    Jan 2004
    Posts
    4,910
    Sonoma County
    Yanmar YM240 and YM186D
    Quote Originally Posted by ttrap
    Does an implement on the back leak down also?
    If not, then the problem is likely in the loader assembly, not the Yanmar tractor. As Wayne (LMTC) noted your seller may be the only person familiar with that model of loader.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
