Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jul 2008
    Posts
    17
    Default 3 point hitch repair
    I am having the 3 point pulse problem that many have experienced. Also, the implement will lower once the tractor is turned off. I'm pretty sure it is the packing, rings, etc. that are on the piston but I also seem to have a small leak on the FEL joystick. I will check that and also change out fluid and filter. Should it indeed be the piston ring, packing, etc., my question is who has done this repair? I like doing most of the work myself and have repaired the 3 point system in my 8N. I have searched the posts but it does not seem as if anyone has done this. Any thoughts?
    Branson 3820i.
  2. #2
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,646
    Red Bluff, CA
    Changes often!
    Default Re: 3 point hitch repair
    Not hard to do, and you can be sure that it is the seals on your piston. You do not have to remove the rockshaft assembly. You can pull the seat and some sheetmetal and get the piston out of the front and replace the seals or the assembly and you are good to go. If you have repaired an 8N system, you are savvy enough to do this.
    Not a bad idea to change fluid and filters, etc., but your problem is the piston sealing in the bore.
    Dave
    Red Bluff, California
  3. #3
    Member
    Join Date
    Jun 2012
    Posts
    39
    Hulbert Ok.
    massey ferguson gc2300 ,jd 300 kubota g1800 2535 century
    i have just repiared a 4520 very well built but it was not the piston it was a peace of metal under one of the vavles you have to pull lift cover to get to it
    very simple to do . i have done alot of lift repiars on other tractors , and this was alot simpler
Similar Threads
  1. JD 3 point hitch repair
    By jimbyfield in forum Parts/Repairs
    Last Post: 10-09-2012, 02:57 PM
  2. Kolpin 3 Point Hitch vs. Johnny Products sleeve hitch
    By grievek in forum General Lawn & Garden
    Last Post: 04-01-2012, 02:29 AM
  3. 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader
    By JOHNTHOMAS in forum ATVs & Utility Vehicles
    Last Post: 06-06-2011, 11:32 AM
  4. adaptor from 3-point hitch to Allis Chalmers Model G hitch?
    By FredWalter in forum Build-It Yourself
    Last Post: 04-25-2010, 03:13 AM
  5. 3 point hitch & land pride quick hitch
    By shrekbelly in forum Kubota Owning/Operating
    Last Post: 08-06-2009, 05:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
