ROP lights and work light addition
   / ROP lights and work light addition #1
Jamesfowl
Kioti DK35SE
The ROP light switch is wires through the spare fuse in the fuse block. The work light is wired through the work light fuse in the fuse block. I think the Kioti factory work light has the switch on the light itself.
   / ROP lights and work light addition #2
Nice set up for the lights. Did you use a relay setup or just tap into the factory wiring?
ROP lights are on their own circuit through a relay mounted under the steering column. Work light is direct wired to a switch through factory work light wiring. A factory installed work light is direct wired.
