>>>>R2500 GIZMO ON COWL ????
   / >>>>R2500 GIZMO ON COWL ???? #1
BearKiller
Located on the "instrument panel", cowl, whatever it's called, on the upper portion, right-hand side, is an about one-inch round dome-shaped metal gizmo with a series of holes, much like a salt-shaker lid.
What is this gizmo ??
Also, just below and a touch farther to the right is a chrome-ringed black push-button; I am assuming this is factory original; what is this button supposed to be ??
Thanks.:cool:
Glow Plug indicator.
Is it supposed to light up or something ?? or maybe be a buzzer ??
I haven't noticed it do anything.
I am pretty sure the glow-plugs work, as the longer I hold them ON, the quicker/easier it starts.
Thanks.:cool:
   / >>>>R2500 GIZMO ON COWL ???? #4
There is a small coiled wire in there that will glow red hot if you hold the glow plugs on long enough.
Hmmmmm........, I will have to check that out; I would have figured it to be a buzzer.
Of course, the wires under there may be hanging loose and it not even be connected, I will check that first.
Thanks so very much for the information.:)
   / >>>>R2500 GIZMO ON COWL ???? #6
the salt shaker thing is most definitely a glow plug indicator.when it is red means the glow plugs are ready.if you look through the holes while heating the plugs you will c the filament glow.
Thanks.
I have been watching for the glowing filament but ain't seen any action yet.
The glow-plugs themselves must work, though, as the longer I hold them on, the quicker she starts.:)
It was getting dark and I needed to move the tractor.
I held the plugs on for a few seconds, maybe ten, while looking down into that salt-shaker gizmo.
In daylight, I hadn't seen any activity whatsoever, but this evening, at almost dark, I could see the little coil glowing red-hot.
If that salt-shaker wasn't in the way, it would make a dandy cigar lighter.:D
   / >>>>R2500 GIZMO ON COWL ???? #9
ah haha yea right.
2008 FORD F750 SUPER DUTY BUCKET UTILITY TRUCK (A50854)
2008 FORD F750...
LOOK! (A50657)
LOOK! (A50657)
2008 Big Tex T/A Utility Trailer (A50860)
2008 Big Tex T/A...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
