ihuntbear
Gold Member
- Joined
- Jan 19, 2010
- Messages
- 422
- Location
- new brunswick, canada
- Tractor
- 2015 tym T554 and 1999 Kobota m4700
is there a turbo on that unit.if so ,a blown turbo can blow white smoke and loss of power but still run rough
If the injector coming out of the rear cylinder is wet, I am assuming with fuel due to the fact that the smoke stops. Low compression is the culprit. Does it run good initally then start acting up or did this happen instantly and will not stop now hot or cold? If it starts ok then gets worse check the valve adjustment. a valve adjustment with insufficient clearance can hold a valve slightly open. If run like this you can burn a valve on the seating surface and damage the head. I really believe a compression test is needed and possibly a leakdown test. Having smoke and wet nozzle indicate the fuel system is injecting fuel, but with low compression it is into a cold cylinder, causing white cold smoke. If you need to improvise a leakdown test you can pull the valve cover, bring the rear cyl onto tdc compression stroke, remove the injector, remove the air cleaner, blow into the injector hole with a rubber tipped blow gun. If you hear air out the exhaust, its a bad valve, if you hear it out the intake it is a valve. if it is either, remove the rocker arms as an assembly, and retest. If it goes away it is a adjustment or you were not on tdc comp. If not pull the head. If it escapes into the crankcase it is a piston or rings.
This is a half-assed test method and I firmly suggest a true compression and leakdown test.
I don't know anything about your engine but I do have over 50 years troubleshooting engines. This is a shot in the dark but you might have a hole in the piston or a broken valve. If you don't have a diesel engine compression tester can you remove the rear ignitor plug and pump air into that cylinder. Some air nozzles have a rubber end that will allow you to pressurize that cylinder. If air can be pumped into the rear cylinder remove the oil filler cap and if you have air hissing out you either have a hole in your piston or seized rings. If the hissing of air is coming out of the exhaust stack you have a broken, burnt, or seized exhaust valve. If the hissing is coming out of the intake you might have the same problems with the intake valve. Like I said it is a shot in the dark but I've used that method successfully for years. Are the valves adjustable in that engine?
Good luck,
Jim
