BX24 Plowing Advice
   / BX24 Plowing Advice #12
unless it changed, the frames on the smaller models was not the same...
   / BX24 Plowing Advice #13
Didn't know there were any smaller models of the BX2000 series.
As far as I can tell all the BX2000 series are the same frame and size.
What smaller models are you talking about.
L . B .
   / BX24 Plowing Advice #14
Next year buy chains and use a back blade. Works great in NW PA...
   / BX24 Plowing Advice #15
This little tractor is an animal in deep snow here in central MA. My problem is that often while plowing with the 2763 blade, the front tires lift off the surface, and I start to go wherever forces want me to. I'm in 4WD, with the differential lock set, turf tires, backhoe on, and floating the plow blade with no down force other that the weight of the blade. Sometimes, steering is pointless. Any advice? Smaller "bites"? That initial path out of the garage is often comical.
No tractor steers very well with the front wheels jacked up off the ground .
reduce the down pressure on the blade and lessen the angle.
   / BX24 Plowing Advice #18
chains on blacktop is not the greatest idea. you slip more then you get traction.
I know what you mean about the float mode digging in with heavy snow. It makes the FEL arms seems to bunch up after you push a few feet and the blade is really full. I found that that pushing it into float mode to let it find the ground first then take it out of float and tap it so I can feel the blade is off the ground but still touching. As I go along, I keep my hand on the FEL control to keep lifting it up a hair at a time due to all the snow rolling pressure pushing the blade down to the pavement. I find I need to do this more over the yard then on driveway.
If you dont see how this really helps -- do the procedure above and after pushing heavy deep snow for more then 10 ft, then stop. note the position of the blade, then back up. You will find the blade "pops" up off the ground. All the weight of the snow is pushing down on the tires for the best traction but if there is no lifting force, you are going to get the bunched up feeling no matter if front blade or FEL.
2018 Ford F-150 4WD Pickup Truck (A50860)
2018 Ford F-150...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2015 MACK GRANITE DAY CAB (A50854)
2015 MACK GRANITE...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2005 Kia Optima Sedan (A50860)
2005 Kia Optima...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
