Stump Bucket
   / Stump Bucket #1
wkpoor
Amanda, OH
John Deere 5400, Farmall H, Farmall Cub, Allis Chalmers CA
I did a search and found a few posts. Still thought I would revive the topic and try to get some more reviews. I have a JD5400 w/520 loader. Possibly a little more tractor than the average TBN member so I was wondering if a 60 PTO HP tractor will have the muscle to really work this implement or not. Not looking to replace a BH just something reasonably priced to do occasional small tree and bush removal.
   / Stump Bucket #2
Stump buckets vary subtlely in design. I have only used the one I bought. It is not worth having except as a platform for modification. Its like trying to push a pyramid into the ground. Even a 12000# tractor couldnt do much.
larry
   / Stump Bucket #3
They vary in construction and price too.
I stopped to look at one last Friday - Built pretty much the same as Markham's grubber bucket, only it had teeth that were cut from 3/4" steel and welded on, rather than the pin-on ones Markham uses.
List price was $995.00. I told them that Markham would build one in their NC shop an ship it to me in WI for less than half that.
All of a sudden it can be had for $600.00 (I still like Markham's better).
My main issue is also whether my tractor can effectively use one. I think that soil composition would play a large role here as to whether or not it can dig as advertised...
.02 as always...
Lunk
   / Stump Bucket #5
Awesome video demonstrating the power of a tracked skid-steer.
It raises a whole new question for me though, which also applies to using a backhoe to remove stumps:
Why not fork over 25-50 bucks and have it ground out??? I've had 6-12 stumps ground out over the last 15 years or so. Other than having to do a little topsoil filling on some of the bigger ones over the years, as the roots rot away and the ground settles, lawn damage was minimal at worst.
I see some of these 8' diameter holes being dug, and all sorts of rutting of the lawn going on, and cannot help but think that hiring a guy with a grinder makes more sense...
I have a lot of 12-24" rocks sticking partway out of the ground everywhere, and was thinking of using a grubber bucket to help "pop" them out of the ground.
I happen to love "seat-time" as much as the next guy, but not if it results in more "rake-time" for me! :)
Lunk
   / Stump Bucket #6
Lunk I had the same thoughts about grinding. Short of row cropping the next week it seems the less dirt moved the better in all ways.
They did not show prep time to seeding back the turf damage.
   / Stump Bucket #7
I think one difference between grinding verses removal is what you plan on doing with the ground after. For me I plan on going the removal route because I'll be plowing and discing for planting hay. Fortunately my trees that I need to remove are not near that large.
   / Stump Bucket #8
The standard duty Markham "grubber" bucket will be a PERFECT match for your tractor. You will dig with it like mad. Mine was less than $550 delivered to my door.
I've been using mine to trench the last couple weeks and my only complaint is that I wish I had more tractor power and a wider stance..... both of which you already have.
   / Stump Bucket #9
Lunk
I agree, grinding them down (to however far below grade you want) makes far more sense.
Maybe not as much fun, just more sense.
I think 16 inches below grade should be adequate for MOST purposes, unless you HAVE TO run pipes or lines through there.
I'd still like a stump grapple, though running them into the ground to get under roots just HAS TO tweak a loader frame ...EVENTUALLY.
That everythingattachments video is on a track steer that can TAKE that sort of pushing, tractors ain't dozers.
   / Stump Bucket
Skid steers and track steers are mean powerful units but in my limited experience don't have the ability to push like a tractor. But they are built studier to take the punishment. I currently use a BoDozer grapple for logging but I wonder if a unit with thumb would let me do some logging and the unit looks much lighter than the BoDozer.
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
71057 (A49346)
71057 (A49346)
