Ford 9n tractor brakes
   / Ford 9n tractor brakes #1
Onustock
Over the past several uses the brakes seem to not want work that great
   / Ford 9n tractor brakes #2
Have you tried to adjust them, since they are mechanical and have no hydraulic assist, as they wear down the peddle will not exert as much pressure on them if the stroke is too long.
Look for a square pin sticking out of the backing plate and adjust it until the brakes get tight then back off 1/2 turn.
Remember that mechanical brakes were never the best system but they should work "ok" at the speeds a tractor travels.
   / Ford 9n tractor brakes #3
Check your axle seals, hyd. fluid may be getting on the brakes. One trick for this is to run it about a gallon low on hyd fluid.
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A50860)
2018 Mack PINNACLE...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2011 Clarke JU4H-UFE0 4 in. Water Pump (A50860)
2011 Clarke...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
