At Home In The Woods
   / At Home In The Woods #1,341
Instead of GFCI outlets consider instead GFCI breakers --- little more up front but they last longer and I don't like the look of the GFCI outlets :)
Also I've seen sparkies be dinged for not using 20 amp breakers for the bath fans.
Kitchens around here are required to have GFCI protected outlets on either side of sink -- each on a different circuit.
   / At Home In The Woods #1,342
First off, I've been reading this thread over the past few nights and actually got to the end of all 135 pages. Do I get some kind of prize?
I have to say Obed, you are very brave for attempting this project under all the conditions you have swirling around your lives. But it sounds like you and your wife have the right mindset to handle it, and that is about the most important thing to have... I'm impressed!
I'm way too late to contribute on foundations or drainage, but I see you are up to electrical, and this is an area I know pretty well.
obed ..just a note on the electrical ..if you are not used to the new GFCI outlets...they are a pain to deal with, at least in my experience. Try to have as few of them as possible. You will be working with a power tool or hair dryer and all of a suden ..no power and then you go around pushing reset buttons...What a pain..I say only in the bathroom and kitchen near a sink ..anywhere else you can eliminate them after you get your final inspection you will find desirable.
They are required by code for countertops near sinks, in bathrooms, outdoors, and in garages and basements (of the unfinished type, not living space). Anywhere there is water. There is a good reason for this. Don't try to skirt it. Since you are having the work done by an electrician, you should get GFCIs where you need them automatically.
GFCI breakers sound like a good idea...until you realize that GFCI nuisance trips can be far more common than breaker trips, and any GFCI nuisance trip will now require a run to the panel instead of just resetting the button on the outlet. Your call, but keep that in mind.
Bath fans draw about the same energy as a light bulb, they do not require anything close to a dedicated 20A circuit. Wire them in with bathroom lights. On the other hand, many microwave ovens take up all of a 15A circuit, and so is best put on a dedicated 20A circuit. Check your Fridge also, as some require their own circuit. Don't let them connect your fridge to the kitchen counter outlets.
One thing I really like to do is run 20A circuits for ALL outlets (they are required for some). Plug-in loads have gone up and up over the years, so having the extra headroom is wise for the future and any high-draw items you may have now. I saw someone else mention that splitting lights from outlets is smart and I agree. The second reason I like that is that while it is good to run 20A circuits for outlets, that 12ga wire can be very difficult to work with on light fixtures that have teeny tiny pigtail wires in them. That plus the fact that lights really don't draw all that much, means I put lights on separate 15A circuits (that use 14ga wire). If you stop and figure it out the actual load, you can put a lot of lights on one 15A circuit, typically (max connected load of 80% of the circuit rating is the standard to allow for minor surges and future expansion).
I could go on for hours here....:laughing: Pre-wiring for a generator is another excellent move several have suggested. I've done that by making several key circuits in a subpanel right away so the generator panel would just replace that directly to run the key circuits in the house. Pulling Cat5e or 6 wire after the electrician is done is a very smart thing to do. Wait until the other trades are done and then pull that, plus RG6 coax, if you can. Sooo much easier before insulation and drywall are up. Just make sure not to run LV wires in the same holes or boxes as power wiring, and try not to run them parallel or you will pick up interferences from the 60 Hz powerlines.
Not sure the requirements in your area, but AFCIs are now required in the NEC in all sleeping areas (bedrooms). These are special breakers that look like GFCI breakers but are different in how they operate. Your electrician should know all this.
Any electrical questions, fire away!
Good luck!
-Dave
   / At Home In The Woods #1,343
I had to have a dedicated outlet for the fridge, and it could not be a duplex receptacle, had to be single. same for the washing machine.
Arc Fault is required a lot of places, but that will be the breaker at the panel.
I have an eat in kitchen (country kitchen), I had to use GFI even for the dining area, but that GFI could not feed a GFI required outside my kitchen door, it had to be seperate GFI. Also was seperate circuit from the counter top two minimum circuits.
I did use one GFI circuit to feed all my bathroom outlets, I have not had a problem, but I have boys, so not a lot of hair dryer action. I have never had a problem with GFI's tripping in the 13 yrs in my house. I do test them occasionally.
   / At Home In The Woods #1,344
Oh there's lots more detail behind all of the special stuff required in the code (like kitchen appliance circuits)...but Obed is using an electrician, so he shouldn't need to deal with most of it, so I tried to hit the things he might need to make choices on.
Some people have no end of trouble with GFCI nuisance trips. Some never see them. Me? I've had a couple happen but that's about it over the years.
-Dave
   / At Home In The Woods #1,345
Other than the bathroom counters, if I need a GFI circuit, I use GFI breakers. If something trips, go to the breaker box. Keeps it simple.
   / At Home In The Woods #1,346
Good luck!
-Dave
I agree with you -- but I have seen inspectors require 20 amps -- its a local code in some towns around here. I guess they figure people might want to add a heat lamp?
   / At Home In The Woods #1,347
Wow. That's just nuts! There's no accounting for the local AHJ sometimes...
-Dave
Much of the main floor wiring has been pulled. My earlier description of the garage and kitchen wiring circuits wasn't quite accurate. Fridge, microwave, 2 ovens, are all each on dedicated circuits. I think we have 2 circuits to the main floor garage but will have to verify. However, we did not think about dedicated circuits for the freezers in the garage. We will probably have 2 freezers in the garage. We will have to make some adjustments to the garage wiring plan.
I sprayed some expanding spray foam around the conduits in the basement wall. The first picture shows the foam immediately after I applied it. The second picture shows how much the foam expanded in about 60 minutes.
Yesterday I "improved" the duct run that supplies combustion air to the fireplace.
attachment.php
Before
attachment.php
After
The solid duct running to the outside was hanging loosely and was pointed upward toward the sky on the outside of the house. Water ran down it and collected in the low spot inside the duct.
I ran strapping above and below the solid duct where it exits the wall and screwed the duct to the strapping to help support it and give it a slope that drains to the outside. Hopefully, the brick layers will not mess up the slope to the outside when they lay the brick. I added some strapping here and here to help straighten the ductwork.
   / At Home In The Woods #1,350
Make sure your duct extend sout far enough outside to allow the louvered downturnfitting with bug screen to be attached to it after the brickwork
30ft Highway Trailer Co. Lowboy (A56435)
30ft Highway...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
