Looking for something larger than 6' finish mower
   / Looking for something larger than 6' finish mower #11
Depending on where you're at, and what you have to pull it with, but I've got a Ford 917 Flail mower I'd part with. Just need to be near enough to Iowa to justify the trip
   / Looking for something larger than 6' finish mower #12
The Woods RM990 cuts 7-1/2 feet wide - liked my first one so much I bought it a bigger tractor. It's happy with at least 35 pto hp. A little spendy, but the quality is there.
   / Looking for something larger than 6' finish mower #14
It even has a hydraulic offset.:thumbsup:
At the moment I have a 6' Mott flail, 6' bushhog, 62" MMM under a 4110 JD, a D-15 Allis, IH cub with a 6' MMM, IH Cub with 5' sickle mower, and a TC 55 DA NH. Im hoping to find something in the 8' range. I love the huge lawn, looks more like a golf course with a view of a valley and pond. Have two more fields i cut with the bushhog that could be cut with a finish mower, another 5 plus acres. I have planted alot of trees, mostly spruce, maple, and oak. I don't mind trimming around them.
   / Looking for something larger than 6' finish mower #16
6+ acres of lawn. Takes too long and need something to cut the time down a little. Anyone recommend a larger brand that isn't in the six figure catagory. Would prefer to stick to a PTO / three point version.
Whatever you settle on, be sure that the PTO Hp matches the mower required Hp. You do not want a larger mower than the PTO can drive, much too hard on the engine [overheat] and may break something in the transmission [$]
The rule of thumb for rough cut mowers [Brush hog] is 5 Hp for each foot of width. A 5 ft hog needs 25 PTO hp, making the engine 30+ hp. Not sure if the same holds true for finish mowers.
   / Looking for something larger than 6' finish mower #17
I have a Befco 84"...works fine ...they make a 110" mower, also
I have 45 hp on one and 55 on the other. Don't believe I would have a hp problem when the grass gets 4" high even with a 15' mower. Finish mowers pull alot easier as there is not much bulk to grind up.
   / Looking for something larger than 6' finish mower #19
How long does it take you to mow your 6+ acres with your current setup?
One of the nicest mowers I've seen is a Lastec articulating deck mowers. They really flow with the ground contours and provide a golf course finish. The make 3PH deck models.
http://www.lastec.com/lastec/index.aspx
When I researched them a couple of years ago, they were serious about providing demos too.
   / Looking for something larger than 6' finish mower #20
Rhino makes a 84" and 100" rear finish mower. I have the 84" rear discharge. Mows great. I bought mine new 3 years ago for $1800 but they are much more $$ now.
I also have a 90" mower for the front of my Toolcat. It is easier to mow with because don't have to look backwards and easier to maneuver.
It doesn't take much more hp for a 84" or 90" finish mower compared to a 72".
You next choice in a large mower is a flex finish mower which will have 3 decks and very $$$.
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2012 Cadillac SRX (A50324)
2012 Cadillac SRX...
2007 CATERPILLAR 257B SKID STEER (A51242)
2007 CATERPILLAR...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
