My Ride-on Tracked dumper
   / My Ride-on Tracked dumper #71
A shot of some 60 track plates I made up on the weekend. Also a shot of a track mock up I am using to shape my drive gears. This side will be contacting the ground. I have come to the realization that I need the gear teeth to come to a point to ensure the track will engage even with some debris in the tracks
That picture of all the cleats (track plates) is where I have to sit back, shake my head, and just say WOW.:thumbsup: There is no way that I would make it through that stack without giving up and quiting.:laughing: My hat is off to you sir for your perserverance to see it through to the end.:thumbsup::thumbsup:
Thanks. I have no choice, I gotta getter done. I want to build a tear drop trailer in a bad way and no room for two projects. I am using a weeks vacation later in Sept to kick this into hi gear. Other things keep popping up, like going deaf which I thought was due to the knobby tires on my truck, put some new car-like snow tires on this weekend and the howling is still there. Must be a wheel bearing going out. Glad I did not wait another week or two on that one.
   / My Ride-on Tracked dumper #73
David:
Those tracks look great. I'm with Cyril in admiring your perseverance in making that many.
Worked my but off the last couple of days to get a track on and see how things will fit. The track weights approx 150 lbs depending on how strong or weak I am this week. Its, if nothing else, going to look good on those tracks. I have a weeks vacation coming up so look for more progress in a couple weeks.
   / My Ride-on Tracked dumper #77
That is going to be one mean machine! I'm excited to see the progress. Thanks for keeping us all posted on the project.
   / My Ride-on Tracked dumper #78
that is so cool! it definatly takes a lot of dedication to do that. Excelent job! :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
   / My Ride-on Tracked dumper #79
Look good nothing......
......it's going to look awsome on those tracks! Nice job.:thumbsup::thumbsup: My hat is off to you sir.
hello
David Devuono, you might want to be careful of those wheels.
LOOKNLEARN was right on with the wheels. I noticed one flexing when I was moving it around the driveway the other day. So now what do I do? I am looking at another 600-800 dollars to upgrade the wheel rim assembly. Having more time then money I am looking at making 20x (3/16 by 5in dia) discs and welding a 2" piece of 1 1/2 inch inside dia tube. Then slide this over the long side hub of the wheel assembly and bolt this on.
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
550 Gallon Water / Chemical Tank (A50860)
550 Gallon Water /...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
