My Ride-on Tracked dumper
   / My Ride-on Tracked dumper #71
A shot of some 60 track plates I made up on the weekend. Also a shot of a track mock up I am using to shape my drive gears. This side will be contacting the ground. I have come to the realization that I need the gear teeth to come to a point to ensure the track will engage even with some debris in the tracks
That picture of all the cleats (track plates) is where I have to sit back, shake my head, and just say WOW.:thumbsup: There is no way that I would make it through that stack without giving up and quiting.:laughing: My hat is off to you sir for your perserverance to see it through to the end.:thumbsup::thumbsup:
Thanks. I have no choice, I gotta getter done. I want to build a tear drop trailer in a bad way and no room for two projects. I am using a weeks vacation later in Sept to kick this into hi gear. Other things keep popping up, like going deaf which I thought was due to the knobby tires on my truck, put some new car-like snow tires on this weekend and the howling is still there. Must be a wheel bearing going out. Glad I did not wait another week or two on that one.
   / My Ride-on Tracked dumper #73
David:
Those tracks look great. I'm with Cyril in admiring your perseverance in making that many.
Worked my but off the last couple of days to get a track on and see how things will fit. The track weights approx 150 lbs depending on how strong or weak I am this week. Its, if nothing else, going to look good on those tracks. I have a weeks vacation coming up so look for more progress in a couple weeks.
   / My Ride-on Tracked dumper #77
That is going to be one mean machine! I'm excited to see the progress. Thanks for keeping us all posted on the project.
   / My Ride-on Tracked dumper #78
that is so cool! it definatly takes a lot of dedication to do that. Excelent job! :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
   / My Ride-on Tracked dumper #79
Look good nothing......
......it's going to look awsome on those tracks! Nice job.:thumbsup::thumbsup: My hat is off to you sir.
hello
David Devuono, you might want to be careful of those wheels.
LOOKNLEARN was right on with the wheels. I noticed one flexing when I was moving it around the driveway the other day. So now what do I do? I am looking at another 600-800 dollars to upgrade the wheel rim assembly. Having more time then money I am looking at making 20x (3/16 by 5in dia) discs and welding a 2" piece of 1 1/2 inch inside dia tube. Then slide this over the long side hub of the wheel assembly and bolt this on.
UNUSED Woven Landscape Fabric Squares (A50860)
UNUSED Woven...
UNUSED 2-Ton Lever Block (A50860)
UNUSED 2-Ton Lever...
John Deere Riding Mower (A50860)
John Deere Riding...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2012 John Deere 7230R (A51039)
2012 John Deere...
Dell Latitude 5424 Laptop (A48083)
Dell Latitude 5424...
