Weight Distributing Hitch On Dump or Equipment Trailer?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #21
Do you have to modify the trailer to accept the wd? Looks like brackets or something would be mounted on the trailers.
I have two equipment trailers, one 6" channel iron tongue, and one one 12" I-beam tongue. I can make one hitch work on both, correct?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #22
You do have to mount the brackets to the trailers a-frame for the WD hitch. The brackets I use are "pinch" type that do not require welding or drilling to mount. The draw back is the trailers frame rail that you mount them to cannot be more than 2-1/2" wide. If your trailers' frames are not wider than 2-1/2" then you can get one set of them and move them back and forth between trailers with ease although I would probably just buy two sets so each trailer is already setup. That is all you need on the trailer.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #23
Crap, there goes my tool box...:(
   / Weight Distributing Hitch On Dump or Equipment Trailer? #25
How much longer does is take to hook up? Looks a little more... complicated than I am used to. A couple minutes would be worth it I guess. I'm country, we just started using balls, lights, brakes, and safety chains a few years ago:eek:. Used to just be pins.:shocked:
   / Weight Distributing Hitch On Dump or Equipment Trailer? #26
If you leave the brackets in place, under 5 minutes for both sides. I run them on our 6'X16' as the hitch load sometimes is in the 750 lb range which is over the 5000/500 limit for non WD of the hitch. With WD the hitch is rated 12000/1200.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #27
The first time you set up the hitch will take a good 20 minutes or so until you have the right height setup and know which chain link to hook on. After that, each time you hook up will take a whole 30 seconds longer than just dropping the trailer on a standard ball.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #28
It takes about as long as hooking up the safety chains.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #29
I use one on my 16' utility trailer.
What would you do if the trailer had front mounted tool box with the pump/controls in it? Would you still be able to mount the WD hitch?
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
JOHN DEERE 6115D TRACTOR (A58375)
JOHN DEERE 6115D...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
