Question on mounting a 730 loader to a 3000
   / Question on mounting a 730 loader to a 3000 #1
Laneman
I have a diesel 3000, around 1973, and a Ford 730 loader that the seller removed from a 2000. Serial number begins with A, which I think is a Belgium made Ford. The 730 loader is supposed to fit my model, but my tractor only has 2 holes that I can see for mounting the front support plate to hold the loader. Looks like the bottom two holes are there but I don't see the top two holes. There are brackets for the radiator deck right where the upper loader plate holes go. Can someone take a look at their loader setup and see if the top two holes are bolted onto the tractor. I don't think the loader is only held on with two bolts, plus the New Holland website shows bolts in the top two holes.
   / Question on mounting a 730 loader to a 3000 #2
are both the 2000 and 3000 a regualr ag model.. or was the 2000 a lcg or?
soundguy
The 2000 looked like a standard blue ag model, but I don't know how to tell what an LCG looks like. I think the 2000 was older, maybe mid 60's compared to my 70's model. Either way, I will have to drill two 1 inch holes into the cast iron front axle support housing on front of the engine. Not the engine block itself, it's a big thick cover in front of the crank pulley that seems to be made for mounting a loader. I may remove the cover to do the drilling so I can use a drill press. I would think drilling those big holes in cast iron with a portable drill would be a nightmare. I found the parts catalog description of the cover, 81845556 Support, Axle, U.K., Antwerp, Except 2300,3300, Start Year: 08/01/1970.
   / Question on mounting a 730 loader to a 3000 #4
if it's cast iron.. it drills real easilly. i'd use a hole saw.. cuts easy. I'd rather drill cast iron than any other metal.. it even drills easier than aluminum...
soundguy
Wow, a hole saw. Never would have thought of that. I think I will try that, I have a 1 inch saw bit that will work.
   / Question on mounting a 730 loader to a 3000 #6
should work fine..
soundguy
The hole saw worked great for drilling the two 3/4 holes in cast iron. Thanks Soundguy for that tip, it was quick and the holes came out very clean. Next I need to widen the front axle by one notch to give clearance to the loader mounting bolt. Last I need to order some of the pump driveshafts part due to worn splines.
   / Question on mounting a 730 loader to a 3000 #8
you did not need to drill no wholes in the tractor u only use to wholes on the plate for a 3000 and for a 3400 you use for and if u put the front mount plate on off a pre 65 model u will have to cut the top of the plate where the top two bolt are so u can put the pump on and it line up correctly to the crank pulley
The 2000 it was removed from used all 4 holes. The parts catalog for a 3000 appears to show all four used. Anyway, I guess an extra two bolts won't do any harm. The loader weighs 1000 lbs empty. Add a yard of dirt and those two 5/8 bolts on the bottom would be under a lot of strain.
   / Question on mounting a 730 loader to a 3000 #10
anything larger than 5/8 into cast iron I usually try a hole saw.. just tends to save time..
soundguy
2025 Wolverine LHR-TWP80 Semi-Trash Water Pump (A50860)
2025 Wolverine...
2016 Freightliner Gradall D152 Truck Mounted Excav (A50860)
2016 Freightliner...
1994 LUFKIN (A50854)
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
