How to ID class 1 3ph implements
   / How to ID class 1 3ph implements #1
Haywire
Central Kentucky
Tractorless :(
Newbie 3ph question.
If I go to a farm auction, how do I identify class 1 vs others if it isn't identified? I'd hate to buy something only to find it doesn't fit.
Ian
   / How to ID class 1 3ph implements #2
Got to TractorSmart and then click on the INFO tab then the Three Point Lift Types. This gives all the info you need. The pin size is the quickest.
   / How to ID class 1 3ph implements #3
I'm sure others can tell you more, but basically it's just the size of the pins used/needed to attach it. Cat 0 being the smallest. If your tractor is Cat 1 but you end up buying a implement with Cat 2 which would have larger holes for the pins than your tractor, you would simply use an adapter for the Cat 2 holes. It's just a short sleeve that fits inside the Cat 2 hole with an inside diameter that allows the Cat 1 pins to fit.
   / How to ID class 1 3ph implements #4
Ian
Cat 1 implements will have 3/4" top link pins and 7/8" lower link pins.
Brian
Thanks, I suppose I can just take some pins to the auctions and check for fit.
Ian
   / How to ID class 1 3ph implements #6
Be a little careful of category II implements for a category I hitch. The other difference beside the pin size is the spacing on the lift arms. Category I is 26" center to center of lift point, Category II is 32". That can cause issues with the lift arm length and interference with your rear tires.
thanks, I won't buy anything but cat 1 stuff.
Ian
   / How to ID class 1 3ph implements #8
Yep, pin size is the quickest. Take a tape measure or a set of calipers with you. I can usually tell just by looking. It is not hard to tell the difference between 7/8" lower pins and 1-1/8" pins on a cat II when you have been around them awhile.
And most of the implements in the size you will be looking at will more than likely be cat 1 anyway. A 4' bushhog, 5' blade or boxblade, 5' mower, all are most likely going to be cat 1.
   / How to ID class 1 3ph implements #9
I was always afraid to ask this question but here goes....what class hitch would my 2001 790 be?
2011 FORD F-450 (A50854)
2011 FORD F-450...
BBQ Pit (A50860)
BBQ Pit (A50860)
2013 Ford F-350 4WD Pickup Truck (A50860)
2013 Ford F-350...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
UNUSED 48 in. Adjustable Pipe Wrench (A50860)
UNUSED 48 in...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
