How to ID class 1 3ph implements
   / How to ID class 1 3ph implements #1
Haywire
Central Kentucky
Tractorless :(
Newbie 3ph question.
If I go to a farm auction, how do I identify class 1 vs others if it isn't identified? I'd hate to buy something only to find it doesn't fit.
Ian
   / How to ID class 1 3ph implements #2
Got to TractorSmart and then click on the INFO tab then the Three Point Lift Types. This gives all the info you need. The pin size is the quickest.
   / How to ID class 1 3ph implements #3
I'm sure others can tell you more, but basically it's just the size of the pins used/needed to attach it. Cat 0 being the smallest. If your tractor is Cat 1 but you end up buying a implement with Cat 2 which would have larger holes for the pins than your tractor, you would simply use an adapter for the Cat 2 holes. It's just a short sleeve that fits inside the Cat 2 hole with an inside diameter that allows the Cat 1 pins to fit.
   / How to ID class 1 3ph implements #4
Ian
Cat 1 implements will have 3/4" top link pins and 7/8" lower link pins.
Brian
Thanks, I suppose I can just take some pins to the auctions and check for fit.
Ian
   / How to ID class 1 3ph implements #6
Be a little careful of category II implements for a category I hitch. The other difference beside the pin size is the spacing on the lift arms. Category I is 26" center to center of lift point, Category II is 32". That can cause issues with the lift arm length and interference with your rear tires.
thanks, I won't buy anything but cat 1 stuff.
Ian
   / How to ID class 1 3ph implements #8
Yep, pin size is the quickest. Take a tape measure or a set of calipers with you. I can usually tell just by looking. It is not hard to tell the difference between 7/8" lower pins and 1-1/8" pins on a cat II when you have been around them awhile.
And most of the implements in the size you will be looking at will more than likely be cat 1 anyway. A 4' bushhog, 5' blade or boxblade, 5' mower, all are most likely going to be cat 1.
   / How to ID class 1 3ph implements #9
I was always afraid to ask this question but here goes....what class hitch would my 2001 790 be?
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A50860)
2025 K0311 UNUSED...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Anvil with Stand (A50860)
Anvil with Stand...
2018 Chevrolet Bolt EV LT Hatchback (A48082)
2018 Chevrolet...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
