WHATS A GOOD IMPACT WRENCH?
   / WHATS A GOOD IMPACT WRENCH? #31
WOW ,WHAT QUICK REPLYS,
My impact gun is an IR 244.according to what i just researched it suppose to have 500 lbs torque?
Guess i need to figure if i got a bad system or a weak gun:confused2:
ALAN
Alan, I think you should be able to loosen most anything with that gun. Can you hook up a short, 10'-20' 3/8" ID line directly to the compressor regular, bypassing all the hose you have running through your rafters/hosereel, and try that? I am betting you will have much better luck. Do you have an oiler on your air line?
I have the IR Titanium quiet gun, worked so-so, I was not impressed with it. I was using 30' of 3/8" OD tubing with an oiler on the gun. Based on advice I got here, I removed the PIA oiler, got 25" of 3/8" ID tubing.. gun now works like it should. I have not found anything it has not been able to loosen.... or break!! :eek:
The oiler was a PIA due to the fact that it was much more of a hassle to fill the oiler every few months than it was to put a few drops in the gun before I used it for the day.
   / WHATS A GOOD IMPACT WRENCH? #32
Actually, one of the best 1/2" drive air impacts is a Sears Craftsman. You can catch it on sale for about 90 bucks and it develops over 500 ft:lb of torque I believe. As someone said before there are others out there that only get to about 250, so you need to be careful on what you are buying. I also use a electric impact (1/2") and it can do 90% of what I need to do, works really good.
Bolting and fasteners are one of least understood mechanical items in industry, they are simple in design, but are used incorrectly many times. Correct assembly will have everlasting benefits during use and will still allow you to remove them easily. Blaster is the best product on the market for loosening stuck anything, I use it all the time. The best bet is to use Anti-sieze during reassembly of nuts and bolts that will be in dirty, dusty and wet environments. Using an anti-sieze at assembly and blaster at disassembly you can use regular wrenches most times for disassembly.
Craig
   / WHATS A GOOD IMPACT WRENCH? #33
My vote is on the hose size/length. My Mastercraft (Canadian Tire) wouldn't even break 100 ft/lb lug nuts with a 25' 1/4 inch hose. Changed to 3/8 and much better results, 1/2 would be better yet. Mine runs 110 psi max.
Also check the internal bore of any fittings in the pipe/hose. It only needs one choke point to cause problems.
You can try tee-ing in a gauge near the gun, but you'll need a damper of some sort or the gauge will likely not stand the fluctuation.
Sean
   / WHATS A GOOD IMPACT WRENCH? #34
KEVEN J
Where can i get the stuff i need,[Ive never worked with pipe]Does lowes or homedepot sell the pipe elbows fittings etc? Will i need to be some sort of pipe threader for the ones i cut?Im afraid you guys will have to walk me through it.Also can one give me a link on a good water seperatorand regulator to buy? Im heading out now to take pics of my setup now.
ALAN
A few pics of an air system
The first is a vibration method and water drain for the riser
The second shows tapping THE TOP for air use
The third shows a dual pressure station with isolation and drain
The fourth is a main line extension with water drain on the wall
I should point out that the main is highest above the compressor and must run down to the end at the drain so air and water travel the same direction.
   / WHATS A GOOD IMPACT WRENCH? #35
Truly astounding. You have a good impact gun that is not functioning properly. Are you using an extension?:eek: - they are springy. More than likely you are starving it for air. Use no regulator. Use no hose reel. Use no extension. Use 50' or less of 3/8" minimum air hose directly out of the compressor tank at at least 120PSI. If it wont twist off a grade8 1/2" bolt take it back. If it wont twist off a 5/8" consider taking it back.
larry
   / WHATS A GOOD IMPACT WRENCH? #36
Yep, that's a good impact wrench; same design as the IR231, just hasn't been around as long as the IR231. But it's been around quite awhile. I repaired one in Feb. 1999, that had the spline twisted off the rotor, so I think it's a pretty safe bet that he was running 175 psi on his air.:laughing: And of course he was a big truck mechanic so he probably let it hammer quite awhile on some of those nuts and bolts.
   / WHATS A GOOD IMPACT WRENCH? #37
We had the problem of the air impact and our system. We traced it to an in-line water trap in the system. It would allow enough air for the grinder, drill and other tools, but not the impact. When we took the trap out of the line, impact worked fine.
Our system has a water filter at the compressor, so no need for another one in the line. The in-line one was from a system that did not have a trap.
All that said, we still have found some things that the air impact still won't budge. In that case, I get out the electric impact. Haven't found anything it wont take off. I can even run it from my truck with a 1500 watt power inverter. The electric impact is from Harbor Freight and cost me $39 on sale.
   / WHATS A GOOD IMPACT WRENCH? #38
Uncharacteristic. Could you give the part #? Id like to check that one out!
larry
   / WHATS A GOOD IMPACT WRENCH? #39
I agree with larry on this one. VERY uncharacteristic.
Did I miss it or did you mention what model the air impact is??
The only way I see a HF electric beating a 1/2" air impact is IF it is a HF air impact or similar.
   / WHATS A GOOD IMPACT WRENCH? #40
For 100' 3/8 hose is good for about 7 cfm. 1/2" will do about 15. If you are going to install new lines this is the best system out there. It's quick and works well. The only limitation is the pipe is rated for 140 psi working pressure(but there's no need to be that high to begin with). The connectors are a push lock, just cut the hose and push it into the connector. We use them at work everywhere with no problems what so ever.
Compressed Air Piping, Compressed Air Systems, Do It Yourself Air Tool System
Northern tool sells it.
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
