grinding/howling noise in 4wd kubota m8950
   / grinding/howling noise in 4wd kubota m8950 #1
tumby
kubota M8950
Just noticed when in 4wd a noise is coming from the crown and pinion area. Anyone have any ideas of what it could be? It sounds like its running dry somewhere, have checked oil/grease etc can't see anything wrong....:confused:
   / grinding/howling noise in 4wd kubota m8950 #2
if you are in very tight turn it may just be hopping/binding, how often are you greasing the frint wheel drive and propeller shaft bearings/spiders/steering yokes/main steering pins-upper and lower fittings?
If this tractor has a planetary wheel drive in the front have you checked the oil levels in the
planetary gearboxes on the front wheels?
My other question is whether you have trash underneath the tractor and do not see it?
Falcon Power 4-Gallon Air Compressor (A50860)
Falcon Power...
1261 (A50490)
1261 (A50490)
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
ASSET DESCRIPTIONS & CONDITION (A51222)
ASSET DESCRIPTIONS...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2014 Ford Fusion Sedan (A48082)
2014 Ford Fusion...
