JD2320 - split SCV hard lines to both mid and rear remotes?
   / JD2320 - split SCV hard lines to both mid and rear remotes?
He is not talking about adding another valve, he is talking about splitting the stock SCV outputs to 2 sets of couplers and using a director valve to decide which set of couplers gets the pressure when the stock valve is actuated.
OP, it will work just fine. Deere actually makes a loader/mower diverter valve (LVB25822) so you can have the MMM and loader on @ the same time without disconnecting one or the other. 2 of those and you have what you want.
Glad you understand I'm talking about diverting flow only. :)
The LVB25822 is not quite what I want. It is mechanical. It uses and alters the front side of the mid quick connect couplers. I dont think there is room for two. It does not add rear remotes.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #12
The problem is JJ does not understand how JD mounts the valves...That why he is confusing all of you.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #13
Hi all hydraulic experts. I've searched and not found a direct match to my idea to split the SCV hard lines. My thought is to remove/somehow use/replumb the factory JD 2320 SCV hard lines through electronic diverter vales so that you end up with both mid and rear remotes that utilize a toggle switch to simply switch between mid/rear remote activation, all factory joystick controlled of course?
Is this possible to achieve?
Yes, very possible-except for the very limited real-estate available on your 2305, and the steel hardlines going from the SCV to the QD's.
Your best bet is to add a new valve-probably on the ROPS just above the fender and feed it with the PB lines that would feed a backhoe. Simulat to these:
Installing a 2 spool SCV on a JD 2320 - TractorByNet.com
2520 - Rear Remotes Added - TractorByNet.com
Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 - TractorByNet.com
It may cost a little more this way-but in the end you'd be much happier, I promise.
Thanks Kenny. Those are great links and great detailed valve installations from members. I of course was hoping you might get involved in this thread and say yes it can be done easy just the way you want... Oh well. If a new valve will make me much happier, guess I will take your sage advice. I have some questions on the PB. I think I'll start a separate direct thread on this.
   / JD2320 - split SCV hard lines to both mid and rear remotes? #15
Your welcome...I just replied to your other thread as well.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
71050 (A49346)
71050 (A49346)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Misc Items (A50860)
Misc Items (A50860)
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
19009 (A48082)
19009 (A48082)
