Spring Plowing
   / Spring Plowing #1
deereman10
Elroy, WI
John Deere 2440
Well the snow is finally gone here in Wisconsin and I cant wait to get on the tractor and get started with spring fieldwork. What's the earliest you guys get in the field and start plowin dirt?
   / Spring Plowing #2
When the field is free of frost and has had a chance to dry, including the low spots.
Nothing worse than gettin part way through a mud hole. And working up wet clay will haunt you until next spring.
Wait until after the snowstorm tomorrow too. :D
   / Spring Plowing #3
All of which I why I fall plow.
100% agree with BeenThere. Make a mess too early, you'll regret it all season.
   / Spring Plowing #4
The best surprise for me since getting a 4wd tractor 6 years ago is that my spring planting gets done an average of one month earlier. To me that is a bigger deal than even the 20% fuel savings the 4wd produced. My flat, bottomland farm has many mudholes that take a good while to dry out in the spring, but the 4wd will plow right thru them with hardly even any wheelspin. It is cool watching the wakes roll off the plow as you pull it thru standing water. Back when all I had were 2wd's, I dreaded spring plowing and always kept my biggest tractor in reserve before complete dry-out, in case I got the second biggest one stuck (happened several times each year). Now I also love it, and I have not been stuck in 6 years.
   / Spring Plowing #5
Lived on a farm all my life never ever saw my dad spring plow, he only plowed in the fall. He probably told me the reason 1 time but cannot remember, cannot ask him either as he has passed.:( Iwish now I would have listen to him more, he was a Jack of alltrades/ master of none.:)
   / Spring Plowing #6
Well, if your dad was like the men in our farming families, they likely would have said this.
Fall plowing allows the winter's freeze thaw cycle to break down the clay into powder. It's a fact.
Fall plowing means its done. The ground is plowed. This gives you freedom in spring to relax and wait for the ideal time to run the disk or drag over it and plant.
Fall plowing means the ground is furrowed, allowing the spring sun to hit twice the square footage surface of the earth, warming it more quickly than if the ground were flat.
Fall plowing means the spring sun can warm the ground allowing earlier tilling and planting.
Fall plowing means the bottom of the garden furrows will hold and trap leaves and other blowing debris better for natural composting.
   / Spring Plowing #7
We farm several hundred acres and we plow it all in the spring for a lot of reasons, a couple of which are:
1. It gives our winter cover crop time to grow enough to be beneficial organic material when turned under.
2. If plowed in fall, our up land would wash away and the river bottoms would blow away.
   / Spring Plowing #8
Spring feild work can very from as early as St Pat day to as late as Mothers Day. If it gets to be Mothers day we are running double and triple time.
ps Plow in the fall, chisel plow that is.:thumbsup:
   / Spring Plowing #9
Precisely right for your management system, climate, conditions and so forth.
   / Spring Plowing #10
Oh, and just to emphasis the difference climate and geography makes:
Most of Wisconsin and northern Michigan got a foot of snow today! Not supposed to be much above freezing for daytime highs for the next 6 days. Yup, April 1 is just a week away, but there are certain realities up here that we just live with.
Talk about working the ground will be delayed for some time. :(
2016 Dodge Challenger SXT Coupe (A48082)
2016 Dodge...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
71053 (A49346)
71053 (A49346)
2012 Honda Civic LX Sedan (A50860)
2012 Honda Civic...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
