new style b7100
   / new style b7100 #11
Did you replace the radiator cap.
This worked wonders for my B7100. Get a genuine Kubota with right psi specs.
Also check for leaks at the Dynamo housing bolts or gasket that joins to the head.
If it overheats the warning whistle should blow (cute)
I have had this happen to me several times working the tractor in 100 degree plus temperatures ( with a now repaired gasket leak) but the tractor has not sustained any damage.
I would not consider parting with this very reliable and popular tractor. It has served me well for 15 years despite neglect and very heavy work in a hot climate.
   / new style b7100 #12
Tractors without water pumps, but with radiators are very touchy on antifreeze/water ratios. IIRC my old yanmar was 60%water to 40% antifreeze. I'm sure someone on here knows better.
   / new style b7100 #13
The less antifreeze to water in the mix the greater the heat transfer.:)
   / new style b7100
i love the tractor, bought it new in 1990, just replaced the mower belt last year!!!!! how many tractors can you say work this good??? and i mow alot of grass, no i didnt replace the cap. i have tightened the fan belt, see no leaks around the dyno unit. i am running straight anti freeze right now. i just drained out what i had it winterized with when i steam cleaned the radiator this spring, and put it back in. there wasnt any dirt or anything that come out of the core when i cleaned it either? i thought my overheating was due to the funs being plugged up because i run it one whole summer without the screen on because it fell off and i ran over it chewing it to smithereens!!! and it was p[lugged up bigtime, however it didnt boil over yesterday, it was very close to. it was venting out the overflow. im sure if i dont find the problem when it does get hot this summer it will indeed boil over again. thank you everyone for trying to solve this issue. im not sure where to turn next, going to try a radiator flush next, then dilute the coolant with water .:thumbsup:
   / new style b7100 #15
Window screen on the outside helps catch the fluff and is easy to clean.:)
   / new style b7100
dont have any fluff just yet. and i think they should have mounted the oil cooler in the center of the radiator instead the bottom....this is the important cooling spot for the engine....and its blocked with the oil cooler!!!! jmo
   / new style b7100
yes i do know that the book says not to run straight anti-freeze. i didnt think mine would get hot just mowing my runway when the weather wasnt very warm. perhaps this is my biggest problem!!! will drain it....and add all water....then drain some out and add a little bit of anti-freeze. what good is anti=freeze in the summer anyway if it dont cool?....just corrosion protection?:D
   / new style b7100 #18
My Kubota manuals said to run a 50/50 antifreeze mix and a factory service rep told me to never go any stronger mix. That was when I had a 1995 B7100.
   / new style b7100
im thinking more like 60-40....till winter again anyway!!!
   / new style b7100
anyway, here is a shot of the original cap....you can see where some of the outer gasket is worn away. otherwise it looks like its sealing good on the inner portion, but im going to replace it, and dilute the anti-freeze, see what happens then. pops says the fan belt isnt tight enough but i disagree with that. if i tighten it anymore than it is, im going to burn up bearings!!!
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
Misc Machine Tools (A50860)
Misc Machine Tools...
1992 New Holland L553 Skid Steer (A50657)
1992 New Holland...
71052 (A49346)
71052 (A49346)
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2001 Great Plains 3N-3010P-4875 Grain Drill (A50657)
2001 Great Plains...
