hydraulic couplers what do i need?
   / hydraulic couplers what do i need? #1
john m
Inverness,FL
cub cadet 149
i have been trying to find a 7/8 ORB fitting for my haldex pump to run my loader. i want to use 37 jic reuseable fittings on the hoses for the pump to the valve and reservoir. i came across these fittings but they are listed as #14 SAE is that the same as fractional values? i want to run 3/4 Inch supply hoses on the pump and 3/8 off the working ports. any help on this.
i have several pages on that site book marked, but that is the ORFS fittings. my pump is 7/8 ORB Female ports.
   / hydraulic couplers what do i need? #4
The #14 refers to 16ths." in size. #14 = 14/16 = 7/8. #12 is 3/4, etc. ORB fittings use same thread size and pitch as 37 degree (JIC) flare.
okay, now i understand. i`m going to call them tomorrow and see what i can get, but i need to do some measurements first. thanks
   / hydraulic couplers what do i need? #6
The dash sizes do refer to 16ths of an inch, but please note that these are nominal sizes, and NOT thread dimensions.
Just as 1/2" NPT (pipe thread) doesn't have a thread OD of 1/2" neither does 1/2" JIC or #8 SAE (O-Ring Boss).
For a break down of nominal sizes, dash sizes, and actual thread dimensions, please see the Fluid Port Size Charts at DiscountHydraulic Hose.com
i`ll call you and see what you have.
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
44052 (A55852)
44052 (A55852)
2018 JLG 600S TELESCOPIC BOOM LIFT (A52709)
2018 JLG 600S...
TANK MANIFOLD (A58214)
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
2013 Peterbilt 348 T/A Liquid Transport Truck (A55973)
2013 Peterbilt 348...
