Tractor Sizing 20-23 or 30 hp tractor
   / 20-23 or 30 hp tractor #1
nmeltzer
After waiting and saving for many years, I am within a year of purchasing a 23-30hp kubota ( or john deere). Where I live in Maine our driveway is 800' plus long and I also intend to get a logging winch ( and in time a backhoe). I am inclined to get a front mount snowblower and am thinking that it should be a 60" model. Where moving snow will be onte of the primary factors for sizing the tractor, I am looking for some advice ( and model suggestions) on tractor size so that when we get 12-18" of wet snow in a storm ( like we had this winter), the blower width and tractor hp will be correctly matched. Any suggestions would be much appreciated. Thanks
Neal
   / 20-23 or 30 hp tractor #2
I recently got a flyer for a logging winch, the smallest model requires 40 hp. Smaller hp might run the winch, but not at full capacity. The snowblower should list the required hp band. It would be wise to stay at the top of the band. I would also say if you get a gear drive, get the creeper gear option. Maybe a HST. I have a 26 hp gear drive, not sure if it goes slow enough to run a snowblower.
   / 20-23 or 30 hp tractor #3
If it weren't for the logging option, you could probably use a <25 hp model. My GC2310 moves snow like there's no tomorrow, and the 48" front-mount blower --which was the main reason I got it, as well-- has no trouble with wet snow. Perhaps a bit slower, but it still throws 25-30 feet. Dry snow, 50+ feet.
Problems- Somewhat iffy, though possible, to get a cab for the SCUTs. Much easier, I think, to get one for the larger tractors. If you really intend to do some logging, better go to a larger, heavier tractor with more hp. (And a cab!)
If you want to see a SCUT up close & personal, an Army buddy of mine got one recently; lives in Leeds.
   / 20-23 or 30 hp tractor #4
All small tractors for your intended purpose. You need a 50+ PTO unit with a cab (for snowblowing) or you'll have frostbite on your extremities right away.
Blowing snow without a cab anytime, is miserable.:laughing:
Thanks all, the logging winch will be for hauling out firewood and working our woodlot, not on a commercial scale. All good info.
Neal
   / 20-23 or 30 hp tractor #6
A cab would be nice, although not required-that's up to your comfort level.
The log skidding can be done with a Kubota B series, although I would tempted to look at a L series tractor (more ground clearance for the woods) for that work. I know there are some winches that will work witha 20 hp or so tractor-some local folks usea combo like that for skidding firewood-a face cord or less a hitch-about what I think you want to do.
Will
   / 20-23 or 30 hp tractor #7
+1 that.
For snowblowing, get a big tractor with cab, Kubota M series or JD 5000 series. Period. You'll not be sorry. Besides for any serious garden work, i.e. root vegetables you need to deep plow your patches, remove stones if any, then disc it and till it. Every year. Backhoe, winch is more suitable for M series or JD 5000 series. You will be driving accident about to happen if you put these on B series.
It is impossible to get ONE tractor to do everything (efficiently). I got JD5083E and it has never stopped me, even in 5-6' snow drifts. But for garden work this tractor is not best to say the least. Bed preparation is done quickly, but you cannot plant, cultivate, hill your rows with it. I need Kubota B series for that.
Don't even think you can do the impossible: "Get one tractor to do it all".
It cannot be done. Every job has the right tool for it.
   / 20-23 or 30 hp tractor #8
What did you end up getting? I'm in a similar situation and watch a YouTube channel called GP Outdoors where he lives in northern Ontario and has no issues with a 25hp tractor and 60" front mount blower. I'm debating on smaller hp front mount, or larger hp rear mount. Lots say more hp is better, lots say 25hp is enough
   / 20-23 or 30 hp tractor #9
Not sure about the 50+ for blowing snow. I live in upstate NY, 150 plus inches of snow a year with lake effect that dumps feet. I have the Kubota B2650 with the front mounted snow blower beleive its 62 or 63in whatever the kubota size is. Front mount is about double new FYI I found a 2 year old one for half the price of the new. Kind of sucks taking the brackets off the front to add the blower and to take off and put loader back on, getting the hang of it but its about a 2 hour job, think I can do it quicker as I go. You do lose the loader function which is a con, but in the winter the tractor is only for snow so I dont care. I also have around 600ft of driveway. I also have the Factory cab which has the AC and heat, and I second the cab for snow. I know nothing of logging, but from what I read if you want to log efficiently probably something much bigger then your talking. IF I were you the less than 25hp option is probably good, I would just get it in the B series or the like 2 series JD frame, as it gives you some more frame and weight to work with
   / 20-23 or 30 hp tractor #10
25HP in northern Ontario? No way. Get 65 HP+ and a snowblower to cover your rear wheels. Leave the front for the loader.
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
