Rear Hitch receiver issue with Kubota 900
   / Rear Hitch receiver issue with Kubota 900 #1
belhavenfarm
Member
Today was my first day working with Kubota and I found a little 'glitch'
Of course the Kubota comes with a 2 inch receiver in the front and rear.
I have several different Reese hitches.
The front receiver is 'open' all the way through so there is no issue fitting the hitch in the the receiver.
BUT the rear receiver is 'short'-my hitch could not go in far enough to fit the pin so it stayed connected. :confused:
Am I missing something?
   / Rear Hitch receiver issue with Kubota 900 #2
Two choices that I know of for the "short hole". Cut part of the shaft off or stick the shaft in and drill a hole where it's needed on the shaft. Maybe stick the shaft in and mark it with a marker then drill the hole where marked. Welcome to that's just the way it is, may be a reason but don't matter, that's the way it is.:thumbsup:Accept it and move on.:)
Well at least it is a common issue and not just mine!:)
How in the world to you cut or drill on metal like that. I don't think I have the tools/machine strong enough to do that.
   / Rear Hitch receiver issue with Kubota 900 #4
Maybe your neighbor does if you aren't anti-social.
   / Rear Hitch receiver issue with Kubota 900 #5
Belhavenfarm. I was also caught off guard by the short depth on the rear receiver. I you will be traversing ditches or small creeks, consider cutting the ball holder to a shorter length. If the ball holder sticks out too far, it may drag the ground when the rear tres drop into the ditch or creek, etc.
   / Rear Hitch receiver issue with Kubota 900 #6
For what its worth, I cut the shft off using a chop saw. Took about 30 seconds, the much longer to file off the sharp edges.
   / Rear Hitch receiver issue with Kubota 900 #7
Sawzall works also
   / Rear Hitch receiver issue with Kubota 900 #8
I did one that way and the other one with a metal bandsaw....both ways were quick and painless. :thumbsup:
   / Rear Hitch receiver issue with Kubota 900 #10
Any decent drill with a metal bit will drill it. Any saw with a metal cutting blade will cut it. Blades and bits are common and cheap to buy. Wal Mart or any Auto parts store will have them. Go to any auto parts store that sells "stuff" for ATVs as well as KMrat or Wal Mart and you can find the Reese hitches. Do like the one from the page you sent but shipping costs are killers. Amazon also has free shipping on items they stock for over $25 purchases.
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
