zkurtb
Ran across the following website that has a nice how-to description for easily creating a shallow well.
Driving a Wellpoint
Driving a Wellpoint
You may want to look into using some type of a hydraulic motor so it would it would give you the ability to put it in reverse if you hit a rock. Just a thought a hydraulic post hole digger motor mounted on a beam trolley with electric winch to pull the motor up/down and the pipe out of the hole?
Reg said:Reversing runs the possibility of unscrewing pipe sections from each other.
I don't have the skills or tools to put much together, but it seems if you want to use the PTO to turn a very long pipe fairly slowly and at quite low power, then some form of belt or rope drive wrapped around the pipe could/should work.
Anyway, I still have the problem of needing to know how much water I would likely need to truck in to a site that has none and some estimate of what else needs to be figured for a site that has no power.
Instead of Just using pipe threads to hold the joints together drill a hole the through the couplings and put a bolt through the couplings and pipe with lock nuts to keep the pipe threads from backing out. (like a shear bolt on a brush hog) If you don't have the means or skills to over come this small issue you should just hire the job done. Not trying to be a smart *****.
Regards,
Tim
Well, I am still learning the whole irrigation system now, have lot to learn. I would assume i would need different zones, but i am having trouble finding gpm on sprinkler heads themselves to see what i need.
