Cat_Driver
- Joined
- Jan 15, 2008
- Messages
- 2,359
- Location
- Coachella Ca.
- Tractor
- 2016 Kubota 4060, 2017 Tackeuchi excavator TB260
When you say slow leak, do you actually have to patch the tire? My wife had a slow leak and it was her valve stems that were loose, They had those sensors on them, I tightened them down and they were fine. Also they have washers or o rings in them that can be replaced. Worth looking at if you actually do not have holes in the tires.
My other options would be this stuff.
Ultraseal Tire Sealant | Gempler's
Permanently seals tire punctures caused by objects up to 1/2" in diameter
OR...... if you really have sharp stones or people shooting your tires out, try this stuff.
GEMPLER'S Ultraseal Tire Sealant -- 5-gal. Bulletproof-grade - GEMPLER'S
Bulletproof-grade Ultraseal is an extreme heavy-grade tire sealant that was developed for off-road equipment that is subjected to multiple punctures in tires. Used in military combat vehicles to bulletproof tires in extreme combat situations, but is suitable for other slow-moving, off-road equipment with maximum speed of 25 mph. When installed, Ultraseal protects against tread separation and permanently seals leaks. This results in reduced tire wear for longer life. It guards against punctures, flats and blowouts which reduces downtime and improves safety. Bulletproof-grade Ultraseal seals wounds caused by objects up to ス" in diameter. Inhibits rust and corrosion on steel belts, wheels and rims. Provides all-weather protection (operates from -40ーF to 300ーF) and won't freeze or evaporate inside tire.
