New Holland 1720 Question?
   / New Holland 1720 Question? #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I have a 1720 with 32XX Hrs It starts and runs very well but smokes more than I'd like it to. Would a valve adjustment help or what would suggest?
   / New Holland 1720 Question? #2
Is the smoke black? It could be excess fuel, having the injectors tested would be pretty easy to do.
   / New Holland 1720 Question? #3
How long has it been smoking, is this a new symptom?
Is it blue, black or white smoke?
Does it smoke under full power. Some more details will be helpfull.
How long have you owned it?
I have only owned the tractor about 7 months. It has a short blast of black smoke on start up but that is normal. aftre it runs a while its hard to see anything unless you rev it up a little. At nite you can see it with the headlights on. It may be nothing to worry about but it does get a bad exhaust smell. I'll have the injectors checked, it may be too rich.
   / New Holland 1720 Question? #5
I've had my 1720 for 15 years & put 1800 hours on it. Your observations sound normal.
Starting would generally be an issue if there were injector or mechanical problems.
Older diesels smoke especially during acceleration & heavy load.
I'd run it.
   / New Holland 1720 Question? #6
Same here with mine...
I have around 500 hours give or take and when cranking get black smoke...
Clears right up when warmed up...
   / New Holland 1720 Question? #7
It will do no harm to check and adjust the valves if they need it.
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58216)
2008 TEXAS BRAGG...
2012 HEIL (A58214)
2012 HEIL (A58214)
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
