Need Some HVAC Advice
   / Need Some HVAC Advice #1
scesnick
Garrett County Md. ( Western Md.)
Kubota MX5100
I have a forced air system in my house with a two ton air handler. It is pretty basic really. I have no air conditioning at all and my thermostat is just a basic Honeywell round type thermostat with no A/C capability.
My problem is that last night I woke up at 3am and it was super hot in my houe and the air handler/blower was still running. I turned the thermostat down to 60 and it still didnt turn off. I waited and waited and it never did turn off. I had to shut it down with the breaker.
I am guessing my problem is my thermostat. Am I correct?
   / Need Some HVAC Advice #2
Thats a good start. The stat should have a off position, Try it if it shuts down with that change the stat. If not you may have a stuck relay.
Actually, no off position on this particular thermostat. You just turn it all the way down.
   / Need Some HVAC Advice #4
on thermostat - there should be 2 wires, if not 3 (for fan only operation). I'd disconnect that one wire ( both if you are not sure, the wires should not be touching) and see if it stops running. If thats the case, then bad thermostat and you can replace it yourself. If it still running then the problem is back at the furnace. If the problem is at the furance, call a pro, since there can be dangerous voltages to work with in furance if you are not sure how it works.
   / Need Some HVAC Advice #5
On your stat is there any other control besides the dial?
No, i don't have A/C at all ( live up in the mountains). This is the exact one i have. But not in celsius.
   / Need Some HVAC Advice #7
Pu ll the front cover off and look inside.... Two wires?
   / Need Some HVAC Advice #9
Otay, Pull off the bezel and look inside you should see two wires in there, disconnect one and the furnace should stop. The stat is just a switch. let me know what happens. DO NOT replace stat WITHOUT shutting down the POWER to the furnace. If it does shut off replace stat.:confused2:
   / Need Some HVAC Advice #10
Take cover bezel off, look for the Glass Sealed Tube inside Liquid Mercury / Switch. Take a Qtip and move that to see if it get stuck cause sometimes dirt / grimes get on top of that and it get stuck through time. Also, make sure the Spring Coil move freely too. Lastly, remove one of the Wire inside if the above steps failed and you Furnace should Stop.
Last but not leaset, hope it's the only problem, LOL
Good article here:
How room or building or wall thermostats work
TIPS:
I always spray some air in the Stats after Fall (September) cleaning. Even though the Stats are Cheap. Why bother spending the money if you can keep the dirt of grimes off easily :D.
2019 POLARIS RANGER 4x4 UTV (A51222)
2019 POLARIS...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
1274 (A50490)
1274 (A50490)
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
