Baling hay with 39 horses
   / Baling hay with 39 horses #1
J R
Kubota 3830
I own a 39 hp Kubota and would like to start square baling hay this summer. Any information on square balers would be appreciated. I'm partial to jd or nh
   / Baling hay with 39 horses #2
Welcome to TBN. :)
   / Baling hay with 39 horses #3
:welcome:
When I first read your post I thought you were literally baling hay with 39 horses and though "this could be interesting" :laughing::laughing:
Anyway I do think you could get much better advise posting this question in the Kubota Owning/Operating forum:thumbsup:
   / Baling hay with 39 horses #4
John Deere 14T or 24T are good balers and depending on the area of the country you can find them at auctions or try tractorsmart.com They are not $$ maybe $1000-3000 tops.
They are pretty simple until you get into the knotting and tying mechanism (on any baler) so make sure you run a few bales thru it before buying.
Its not that the knotters are so expensive it's more along the lines of when it's hot and time to make hay and you spend the afternoon fixing the knotter and rain is coming that makes it frustrating.
But when they work they work reliably.
good luck and some more detail about your location might get some other members to suggest best dealers / places to look in your neck of the woods.
   / Baling hay with 39 horses #5
Perhaps this will be helpful. Go the the SEARCH section here on TBN, and type "Square Hay Balers" in the line for threads and then hit the Search button. There are several past threads there that may be of assistance. Good Luck. BTW, welcome aboard.:tractor:
Thanks for the info. I'm located in Tuscaloosa Alabama. Hoping to bale around 400 bales per year. Is there anything in particular I should look for when looking at balers or do you pretty much just have to see it bale?
   / Baling hay with 39 horses #7
I bought my Massey Ferguson 124 baler (two twine, small squares) several years ago right out of the field--the seller baled 30 acres the day before I bought it. Cost: $2K
Stay clear of balers that have been "field stored" any length of time unless you know enough to evaluate the condition of such balers or have a friend you trust inspect the baler before you buy.
I'd get the seller to run the baler for you (bust open a few bales and hand feed them into the pickup) to make sure it works OK. Check the baling chamber for excessive rust on the walls (which is a problem if the baler has been stored with hay packed in that chamber).
Check the slip clutch on the pto shaft for worn face plates (I had to replace the plates on my baler right after I got it home).
There are a lot of JD and NH balers around and you can get parts pretty easily for these. Check parts availability before buying other brands.
Good luck
Thanks for the help. With my lack of knowledge on balers all info is helpful.
   / Baling hay with 39 horses #9
I wouldn't bale at all with 39 horses... they will eat the hay faster than they will ever bale it! :confused2:
   / Baling hay with 39 horses #10
WELCOME to TBN :)
I moved your thread to the Ag Tractors & Machinery Forum.
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
2001 Lexus LS 430 Sedan (A48082)
2001 Lexus LS 430...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
Fuel Tank (A50860)
Fuel Tank (A50860)
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2016 Jeep Patriot SUV (A48082)
2016 Jeep Patriot...
