Why did they put the loader valve lever lock there!?
   / Why did they put the loader valve lever lock there!? #1
Evil the Weasel
Central NY
Kubota B2620
I accidentally locked it with my foot when backing up and the panic set in quick when the joystick froze. UGH. All better now.
   / Why did they put the loader valve lever lock there!? #2
I don't know, but you're scarin' me away from buying new--LOL!
Glad you got it figured out.
My Hoe
   / Why did they put the loader valve lever lock there!? #3
An example may be, if you shut off the tractor with the loader bucket raised up in the air and you want to lay in front of the tractor to fix something with the loader bucket up and out of the way.
Oh my :eek:! The safety police will be all over you. It is not safe to be under a loader supported only by the hydraulics. A hose could burst at any time causing the loader to rapidly fall.
   / Why did they put the loader valve lever lock there!? #5
'Long as you didn't have the FEL maxed out, it's nothing to worry about.
Our orange back-saver is a B2320, new this past July, and we're protective as all heck, so if that happened to either of us, we'd've wet ourselves too.
I don't think either of us has the required knee flex to do what you did...
But both my boss [wife] and I have caught all sorts of clothing on the PTO levers as we climb down off of it- an if'n it's runnning, the grinding gear sound makes you wanna cry...
I guess I should've boughten a bigger tractor so I had the room to dismount safely.
To: the other respondents- he dint aks why it had a lock for the hydro- just why is it where your foot can lock it unbeknownst to yourself...
   / Why did they put the loader valve lever lock there!? #6
The spool lock is NOT for locking up the loader for service. you need to block the cylinder for that. the lock is more of a convenience so that you don't bump the stick and dump something out of the bucket or similar action.
2021 Spartan RZ Zero Turn Mower (A50860)
2021 Spartan RZ...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2000 Dnya RGN (A49461)
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
EZ-GO Electric Golf Cart (A50860)
EZ-GO Electric...
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
