Ford 1320 will not start
   / Ford 1320 will not start #1
rockyranchboss
Perris, CA
Ford 1320
I have a Ford 1320 over 20 years old. The tractor would not start and I replaced the old battery, checked the fuses, cleaned and tightened but the tractor will not start. I have read the manual and can't locate a trouble shooting check list. I would like to do the repair myself if I knew what the issue or part problem was.
Any local Ford Tractor repair make house calls? I am in western Riverside County.
   / Ford 1320 will not start #2
What does it do? If it just doesn't do anything (starter doesn't turn at all), start checking your safeties. Like, it won't let you start if the PTO is engaged.
Keith
   / Ford 1320 will not start #3
ditto.. we need to know more.. is it turning over or not?
if turning over, is it making smoke?
post back
   / Ford 1320 will not start #4
Do you have fuel, is the valve open, plugged filter. When was the last time it ran? did it die or did you turn it off. need more info.
JC,
PNEUMATIC GREASE UNIT (A58216)
PNEUMATIC GREASE...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
LINDE H70 FORKLIFT (A58216)
LINDE H70 FORKLIFT...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
