DP Property
- Joined
- Oct 22, 2009
- Messages
- 195
- Location
- BelleRiver, Ontario
- Tractor
- Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
That's an easy installation. If I can install a PB, and 3 - 5 SCV kits myself, then you should be able to do this. Just take your time, read the instructions, and keep dirt out of the system. I blew air through the lines before installing them to make sure no residual manufacturing crud was in there. Prior to installing these kits, I never touched a hydraulic system in my life.
https://picasaweb.google.com/110106108324823291002/HydraulicsUpgrades#
Sounds good John Deere says 1.5 hrs labor for there tecs is a rule of thumb so if they get 1.5 hrs I am sure I can do it in 3
