1951 John Deere B with a jd 50 power block
   / 1951 John Deere B with a jd 50 power block
I'm thinking your correct on the weak spark.
Well here's the update. A John Deere 60 carb will not run on a 50 series tractor. The throttle size of a 60 is the same as a 730. To much air not enough room make up the ratio. So now we shall track down a 50-530 carb and start all over. Thank you all for helping
   / 1951 John Deere B with a jd 50 power block #23
Sorry for the bad news. You can get a new carb from Stiener tractor part for roughly $250. Good luck.
   / 1951 John Deere B with a jd 50 power block #24
It would help if we knew exactly what you cobbled together. What head and manifold? What cam? The power-bloc compression ratio should have 91 octane.
Mag or distributer ? Timing curve?
Have you tried it without the air cleaner ?
Well it a 50 power block 5" pistons with a 50 head with new valves and springs distributor for a 50 we have a k&n air filter on the end of the 1 into 2 intake. gas intake manifold. Straight pipe exhaust. I notified Poppin John about our problem and he said a 60 carb will never adjust out enough to run a 50. So we order a rebuilt 530 carb. So we will see how she reacts to that.
   / 1951 John Deere B with a jd 50 power block #26
Same carb body is the same on the 50/520/530. There is a variation in Power Jets but the power jet is the same.
   / 1951 John Deere B with a jd 50 power block #27
seems like something could be done with a carb rebuild kit for the 50...
12 in Small Excavator Bucket (A52377)
12 in Small...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2018 Mitsubishi Eclipse Cross SUV (A53117)
2018 Mitsubishi...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
