Lilredfox sending out SOS
   / Lilredfox sending out SOS
oh my. this, i godda reply. ta sum it up. my pa always sed. wen he did my mom he #%&ed the balls ryt offa me. i.e. tomboy with ****. wut of it me gittin my pa's hands. im very proud to have his large Irish hands. indeed a blessing. i cant imagine tinkerin without em. go ahead. keep it up. u cant hurt my feelins nun. yea might jus take a gander at this entire thread. theres more than a hint in it. as to wut it is ur lookin for. i.e. gender identity. now with that set that aside... wut next, u'll say im guy. or the other way... it's not ryt ta judge yea no. jus sayin.
Google gender identification through finger length...just sayin...aside from that, an interesting thread...
   / Lilredfox sending out SOS #153
   / Lilredfox sending out SOS #154
TBN is a Family oriented Forum.
   / Lilredfox sending out SOS #155
I am not translating that last one... :shocked:
James K0UA
   / Lilredfox sending out SOS #156
today is the day i attempt this suggestion. that is if nobody disagrees with it.
After cleaning screen and bottom of the housing out refill with new fluid, add 1/2 a bottle of isopropyl alcohol to the system to dry it out, run it for 15 min or until filter plugs up, drain and refill with clean fluid.
this is round 4 of drainin n cleanin the filter.
i'll also try in re-hook up the fuel system n burp it?
i did find somthin in the seam on top were the cast splits in half. it's a tar like substance. perhaps more of a non hardening black permatex. its not to were water can git in i dont think. Not 3 gals of water anyways.
Hi Lil Red
Looks like you have a severe water contamination problem. Is there anywere rain water is coming in,like a shifter boot or top plate cover with a bad gasket.
or until filter plugs up, drain and refill with clean fluid. If you can park it in a shed or tarp it to keep it dry, that may help if you have a leak.
Send a picture of the fluid you drain next time. If you are still getting debris in fluid, try filtering it through an automtive type paint filter.
Did you get the fuel tank cleaned out, do not run without a fuel filter, injector pumps dont like debris or water.
Dave
   / Lilredfox sending out SOS #159
Water may leak in around that wire, can also enter thru broken insulation in wire, I would clean and seal both with black silicon. How is the shifter boot and any other seals?
Dave
i checked them out as well. both boots are tight. there is nothing anywere that i can find that would permit 3 xtra gals of fluid get in there. and certainly not in a 6 month period of time. not even sittin out in constant rain.
Dave
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
Landoll (A50657)
Landoll (A50657)
2016 Ford F-150 Pickup Truck (A49461)
2016 Ford F-150...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
