Enjoying my David Brown 780 Selectomatic
   / Enjoying my David Brown 780 Selectomatic #11
Welcome to TBN :)
I moved your thread to the All Other Brands forum.
just a test to see if all working
   / Enjoying my David Brown 780 Selectomatic #13
yep, it's working. Brianna is right on top of things doing her job in the background. She does a great job too keeping forums nice and tighty.
Sent from my iPad iOS 6.1 - TBN v1.6
   / Enjoying my David Brown 780 Selectomatic #14
Welcome from Maine
P2040415.JPGP2060418 1.JPGP2140421 2.JPGP2140422 1.JPGP2040416 1.JPGP2140424.JPGP2060419 1.JPG
Here are some pictures of my David Brown 780 Selectamatic refurbish project. Notice the Three point hitch photo that shows the rebuilt sway bars. The seat is a Massey Ferguson seat but with the extra foam and half the cost of an original replacement, I think I might like it better. Fenders are now painted Case Power White. The picture shows just primed.
Well Kid I got some pictures posted on my thread of seats, fenders, Bonnet (Its British) and stripped down tractor. The decals are very faded but I decided to tape them anyway, we'll see if I need very expensive new ones. I will get some pictures of the instrument panel today and show off the New Tachometer That started this whole project. DB Pilot
   / Enjoying my David Brown 780 Selectomatic #17
Looking good DB. How much is the decal kit? Mine cost around $40 I would seriously consider the decals unless they are off the charts in cost. If that's the case, you might consider a vinyl sign shop making some for you. My hood got it's first coat of clear lacquer on it. Wet sand it tommorro for coat two.
Here are a few more photos and the Tachometer that started all this. Today I pulled the Seat mechanism apart. It was a brutal process due to rust and damaged parts. I learned a lot about the "Super Comfort seat". Which is what David Brown called it. Turns out it is the same seat that Ford called the "Rest-o-Ride". Tomorrow I will try to rebuild the seat torsion mechanism, clean up the front wheel bearings and put the front wheels back on the tractor. I want the steering wheel off the tractor but the gear puller doesn't move it. Tried Kroll oil and heat, still nothing.
   / Enjoying my David Brown 780 Selectomatic #19
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=303525"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=303529"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=303523"/>
Here are a few more photos and the Tachometer that started all this. Today I pulled the Seat mechanism apart. It was a brutal process due to rust and damaged parts. I learned a lot about the "Super Comfort seat". Which is what David Brown called it. Turns out it is the same seat that Ford called the "Easy Rider". Tomorrow I will try to rebuild the seat torsion mechanism, clean up the front wheel bearings and put the front wheels back on the tractor. I want the steering wheel off the tractor but the gear puller doesn't move it. Tried Kroll oil and heat, still nothing.
I love that unique patina that resembles bird poop. Very realistic.
I used a rubber mallet on mine. Jacked the front end off the ground so I could easily turn the wheel. I'd give each spoke a good upward swat spin the wheel the next one and hit it and so forth. It took about thirty minutes but patience paid off. I removed the wheel without any damage. The mallet was slowly jarring it loose until it finally popped free.
Message posted with TractorByNet v1.6.2 for iPad
One day about 100+ starlings, I think, broke into the barn and tried to paint about every piece of equipment I own. They have been evicted.
Thanks for the advice to get the steering wheel off. I will try the mallet technique tomorrow. Worked most of the day on the seat mechanism. I can fix it but will be a lot of work just to keep the original looks of the tractor. Well that's what I wanted so I will keep at it.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
