Fossil Farm
Wow, I had to check that, as I am an avid photo buff.
You are right with your description, but..
I just took a thumb drive over with some old pics on it. I have already fixed W-8 to open on the "Desktop" view, which is similar to W-7, but no Start Menu, no shutdown, no reboot, no sleep. Alt-F4 gets you to those choices.
W-8 has already put a "Folder" icon in the task bar. Opening that you get your computer hard drives and other normal folders.
Plugging in the thumb drive makes it appear as another drive.
I opened that and got the details list as normal.
Now this may be because of "Windows Essentials" that I installed.... but I selected "Slide Show" then "Pause" then advanced the pictures back and forth with the Left/Right keys on the keyboard.
Doable for now, but will have to be overcome if 8.1 doesn't fix it.
I've seen a gizmo called "Smart 8" or something on the net that can be installed to make 8 more like 7 but won't mess with it till 8.1 is in and we see how it works.
Change your default viewer to "Windows Photo Viewer" and it should work just fine.
