titan grapple
   / titan grapple #1
dwight jr
Member
southern middle tn
kubota l3800-m9000-jd4430
wicked or titan 48 inch?the titan is a lot cheaper but will it get the job done?if any of you guys have any experience please let me know.thanks!
   / titan grapple #2
Is this for the Kubota M9000 you have listed?
   / titan grapple #4
Don't know much about the Titan but sure like my Wicked 50 inch single lid. I especially like the way the upper and lower tines come together so I can pick up small sticks and rocks.
James K0UA
   / titan grapple #7
The weight of the Titan 48" has been discussed in another thread. They list it as either 450 or 500 lbs, but similarly constructed grapples with the same tine width are in the 300 lb category. Titan ships in a metal frame crate and speculation is they list shipping weight. The wicked is a nice grapple but fairly expensive. I can't see how you you could go wrong with the Titan, particularly if it is in the 300 lb range, preserving your lift capacity. I have one of their other grapples, their forks and one of their adapter plates. Never have had a failure of any sort. But look at the wicked for sure, many people like them.
   / titan grapple #8
I haven't done a write up yet, but I purchased the Everything Attachments Compact Utility grapple back in the summer and I love it. They rate it for up to 35 hp tractors but I put it on my 40 hp Kubota L4060 and have had zero issues. My tractor also weighs almost 6000# so I don't think weight would be an issue either.
It's much cheaper than the Wicked and a lot lighter than the Titan.
   / titan grapple #9
I have the Titan 48" and I have been very pleased with its performance.
   / titan grapple #10
They are solid for sure. Is there any way you can measure the weight of it? Other 48" grapples with the same 3/8" tine thickness and roughly the same dimensions list out in the 300 lb range. Titan ships in a steel frame and on a pallet and I think their listing on 500 lbs is too high, likely a high estimate shipping weight.
New Holland B95 Backhoe (A50490)
New Holland B95...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
