Got a SSQA weld on plate - build ideas?
   / Got a SSQA weld on plate - build ideas? #1
number9L
Gold Member
Georgetown, KY
Kubota L3800
Actually picked up 2 plates for my tractor at an auction today.
Gimmie some ideas what to build for them!!
I need some brush forks but don't like the idea of "wasting" a plate dedicated to be brush forks. But I do have 2, I guess. Thought about fixing a Quick Hitch on one of them to be able to use the carry all or any rear attachment on the front as well. Can't really think of anything I need on the front other than brush forks or pallet forks....
   / Got a SSQA weld on plate - build ideas? #2
If you run some extra hydraulic lines up there with a valve, the sky's the limit. I have used the plates for a hydraulic post driver. It was made to mount to the front of a farm tractor, but I cut the arms off and welded to the plate.
Any farm implement can be modified to fit, like a grapple, post hole digger, etc. You might want to check prices on the forks. If you do not have a set of forks already, a fork setup that is already made to the plate is available fairly cheap at most tractor places. We then modified it with a receiver to accept a round bale spike to lift round bales of hay. Just slide the forks over and take them off and install the spike.
   / Got a SSQA weld on plate - build ideas? #3
I have a quick hitch built on a ssqa plate I use it a bunch for all types of things from moving implements around when I am bush hogging , using a blade on the front and a boom pole for lifting and much more.
   / Got a SSQA weld on plate - build ideas? #4
These pin style block forks will move brush or pallets. :thumbsup:
   / Got a SSQA weld on plate - build ideas? #5
How about a boom pole?
   / Got a SSQA weld on plate - build ideas? #6
That what i'm going to use my spare plate for too. Got some pictures of your set up to share?
I've about got the brush forks done. Just gotta weld them to the plate now. Man I'm glad I'd seen someone mention adding in roll back, cause I would have over looked that for sure!!
Really like the QH on SSQA idea.....
   / Got a SSQA weld on plate - build ideas? #9
Gotta agree with figuring in some rollback, very easy to overlook!
   / Got a SSQA weld on plate - build ideas? #10
The 3 point adapter that I bought has some roll back built into it.
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
Gravely Compact Pro Zero Turn Mower (A50860)
Gravely Compact...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2014 Mazda3s Grand Touring Sedan (A48082)
2014 Mazda3s Grand...
