Best Penetrating Fluid?
   / Best Penetrating Fluid? #11
Kroil is the best you can buy premixed IMO.
Acetone and ATF also work well, but acetone eats paint. So that is its one and only issue. Sometimes you can use it, other times not because of that.
Typically, I am in too big of a hurry anyway and just grab the blue flame. But I always like to spray something on stuck fastners, before I even try them. Because even if it isnt needed, it still helps. ANd I have had things break loose no problem before, and get half way out and seize again...
   / Best Penetrating Fluid? #12
You guys may not believe this, but a torch and a candle work wonders. Heat up the back side of the fastener for a min or so, then melt the wax in the threads on the back side, works like a charm!
   / Best Penetrating Fluid? #13
I have agree thats stuff just creeps in to where you need it.
   / Best Penetrating Fluid? #14
GIBBS is better than KROIL I always used KROIL by the 5 gal. can but found GIBBS and find it better. Have not tried home brew as GIBBS works so good but I will just to see for myself.
   / Best Penetrating Fluid? #15
I have found that quick heat from a torch works far better than any penetrating fluid.
I am the OP and will soak this part with Kroil if I can find it locally. I am going to reposition the blower so the penetrating oil will run into the coupling/shaft assembly. Then I will soak for 3 days or more.
The manufacturer has told me twice that the parts should come apart (blower fan will separate from the gearbox shaft) with a little prying and striking with a hammer. Ain't happening, I have pried and pried, and struck and struck without any movement at all.
Manufacturer says heat could damage the gearbox seal so I am hesitant to do that. Don't really know what to do except keep soaking and then pry some more.
   / Best Penetrating Fluid? #17
Some pics may help us offer some more suggestions
   / Best Penetrating Fluid? #18
I will keep trying to separate my SB51 snowblower fan from the gearbox shaft. I think if I stand the blower up on the auger end I can spray the penetrating oil so it drips into the coupling better, then soak it over a period of days. What is a real good penetrating fluid to use? I have some Liquid Wrench but it's not doing the job so far.
Kroil is #1. Zep is good too . PB blaster is just ok.
   / Best Penetrating Fluid? #19
PB Blaster combined with prudent use of heat... heat can damage seals and bearings, so I'm careful around them, but the heat helps wick the pb into place.
My dad likes kroil, but I find the cost and availability prohibitive, pb blaster is on the local hardware store shelf.
I will admit, I've never tryed atf/acetone, I may give it a shot.
My first attempt to post photos. Here are a couple of the snowblower fan and gearbox.
2011 Kia Optima Sedan (A50860)
2011 Kia Optima...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A50860)
2025 K0311 UNUSED...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2013 Bandit 990 XP Trailer Mounted Wood Chipper (A50860)
2013 Bandit 990 XP...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
