mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,362
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
I have a bit more than 1,000 Lbs. additional iron on my L39, in the form of custom wheel weights and some addition reinforcements to frame and bucket, a mechanical thumb , etc.
I was still surprised that the BH could lift and hold out full extension a 30" ID x 36" OD x 34" tall Well Tile with the hoe full y swung 90 degrees and the stabilizers up. The well tile weighs 800 Lbs. Max. rated crane lift with the hoe is 1,100 lbs, but I do not know if the rating is for straight out full extension.
I did install one 12 tall riser that is 24 I.D. The cover is also 24 so If I ever have to remove that cover, I will have to chisel a bit around the tapered edge. For the24 risers, I will use 30 I.D. x 26 O/D x 24 tall well tiles.
Even with 2000 hrs. on the old girl, the L39 still amazes me.
I have a Komatsu PC75UU2 excavator, as I was killing the L39 transforming the raw land on this ridge turned farm. Now that the heavy lifting is done, I only have put a few hours on the excavator in the last 2 years. The L39 still gets used quite a bit. Plowing snow with an 8' commercial plow, light digging, Lots of loader work, logging, etc. I have a small B7200 for 3 Pt work. and the excavator is better ripping stumps, and placing rocks, but the L39 and the RTV 900 are the machines that are used daily.
They are the tools in the shed you want to keep.
